Speed issues and strange speedtest results..
FIXED- Subscribe to RSS Feed
- Speed issues and strange speedtest results..
27-03-2018 6:14 PM - edited 27-03-2018 7:13 PM
Had a problem. PN reset my profile, during training my Archer D5 reported SNRM of 2.14billion (?). Binned the router. Now on a Billion (router). Line is stable. but speeds are much lower than they were before. Checked the btw test for my profile and many times got similar results. I'm on ADSL Max, these can't be right! I must have run the test a hundred times over two months and it always gives the error message.
1. Best Effort Test:
Download Speed : 14.84 Mbps
2. Upstream Test:
Upload Speed : 0.53 Mbps
Your speed test has completed and the results are shown above, however during the test an error occurred while trying to retrieve additional details regarding your service. As a result we are unable to determine if the speed you received during the test is acceptable for your service. Please re-run the test if you require this additional information.
Router Stats.
adsl info --stats
adsl: ADSL driver and PHY status
Status: Showtime
Last Retrain Reason: 1
Last initialization procedure status: 0
Max: Upstream rate = 940 Kbps, Downstream rate = 8620 Kbps
Bearer: 0, Upstream rate = 752 Kbps, Downstream rate = 4543 Kbps
Link Power State: L0
Mode: ADSL2+ Annex A
TPS-TC: ATM Mode(0x0)
Trellis: U:OFF /D:ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 9.5 7.9
Attn(dB): 44.5 23.4
Pwr(dBm): 20.6 12.2
ADSL2 framing
Bearer 0
MSGc: 57 34
B: 26 23
M: 1 4
T: 4 2
R: 16 6
S: 0.1884 4.0000
L: 1826 204
😧 160 2
Counters
Bearer 0
SF: 7732705 394450
SFErr: 10 113
RS: 1948641385 1580778
RSCorr: 84093 119
RSUnCorr: 316 0
Bearer 0
HEC: 55 72
OCD: 2 0
LCD: 2 0
Total Cells: 983512244 162765585
Data Cells: 55713252 6379120
Drop Cells: 0
Bit Errors: 0 8223
ES: 21 123
SES: 11 9
UAS: 37 26
AS: 91776
Fixed! Go to the fix.
Re: Speed issues and strange speedtest results..
28-03-2018 10:01 AM
28-03-2018 4:05 PM - edited 28-03-2018 7:35 PM
No. Other speed tests are consistent with router stats IE download at 3.6 to 3.8 Mbps. I am certainly not getting that speed. I also notice that if I reboot my router I sync at exactly the same rate each time 4543Mb even if I lower the the SNRM on my Billion router.
31-03-2018 4:06 PM
You're not on Max, @melindwr.
I guess your 20CN exchange was upgraded recently and your line was silently reprovisioned. Openreach has an ongoing programme of upgrading the vast majority of rural exchanges to 21CN (mine was done last year, which is why I've returned to Plusnet from the LLU world).
31-03-2018 5:07 PM
It's also worth bearing in mind the BT speedtest is broken in some browsers.
31-03-2018 5:36 PM - edited 31-03-2018 5:41 PM
Thanks for the responses guys.
If I the exchange has been upgraded, I need to force G.dmt as my sync has fallen by 2 Mbs! I believe I am still on ADSL Max as a neighbour has had an engineer out who told him we are on IPstream. I think the Billion router selects the appropriate modulation if ADSL 2+ is specified and doesn't report the actual modulation used. I definitely think the btw speedtest is at fault here.
I am more concerned with the error "Your speed test has completed and the results are shown above, however during the test an error occurred while trying to retrieve additional details regarding your service. As a result we are unable to determine if the speed you received during the test is acceptable for your service. Please re-run the test if you require this additional information." as I cannot register the results.
Problem is my speed is too high for plusnet to regard it as a fault but much lower than I was getting before..
31-03-2018 5:52 PM
You are definitely on ADSL2+, and your speed has clearly been banded by the DLM. Plusnet could reset it (again) to remove the banding, although the DLM would likely band it again if whatever caused the banding in the first place is still present.
31-03-2018 6:09 PM - edited 31-03-2018 6:10 PM
Thanks ejs. I guess I'll have to take you word for it. Both Samknows and Plusnet Exchange status tell me the exchange is not 21CN enabled. However it looks like my router resynced @6.6Mbs last night
31-03-2018 6:23 PM
Then both those websites are out of date.
31-03-2018 6:37 PM - edited 31-03-2018 6:45 PM
31-03-2018 7:52 PM - edited 31-03-2018 7:54 PM
No worries. The eponymous Sam seems to have stopped knowing things several years ago. The site still talks about Market 1/2, for pity's sake.
