Speed issues again.
- Speed issues again.
Speed issues again.
14-03-2008 5:49 PM
Our u/n is rfowles, id be grateful if someone could suggest something? I don't fancy sitting in a queue on the phone yet again!
Thanks. Rob
Re: Speed issues again.
14-03-2008 6:05 PM
Test1 comprises of Best Effort Test: -provides background information.
IP profile for your line is - 750 kbps
DSL connection rate: 448 kbps(UP-STREAM) 4512 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 428 kbps
14-03-2008 6:38 PM
14-03-2008 7:40 PM
depending on what your router is now syncing at (if its a bt voyager then type 192.168.1.1 in add bar) and go to advanced menu, status, broadband line.
this will tell u what your router is currently syncing at. if it stays synced at this rate your bt profile will update to this in about 3days. yes 3days u can tell your dealing with bt with a wait like that lol
for what bt will profile your line at from the speed your router is synced at try this page.
http://www.plus.net/support/broadband/products/faqs_and_guides/dslmax_guide.shtml
o and have u found out what caused your sync speed to drop so much.
14-03-2008 7:44 PM
15-03-2008 12:47 AM
15-03-2008 1:07 AM
15-03-2008 12:38 PM
15-03-2008 5:09 PM
dmt works with quite a few routers.
if you do give dmt a try there is a hidden menu to set your snr but be cafeful as it can mess your bt line profile up as well as improving it if u move the slider the wrong way.
15-03-2008 6:18 PM
Would be grateful for any info about this tool etc.
15-03-2008 6:47 PM
You want v8.07 for your Linksys WAG54GS.
17-03-2008 2:03 PM
Unless you're contemplating setting the noise margin higher, it could potentially prevent sync drops from occurring.
I'd make sure of the usual things, ensure that you are connecting via the master socket and try using a different filter.
