Speed issues AGAIN
kirsty85
Speed issues AGAIN
Hi plusnet, i had speed issues with you in the past and this has been sorted since i upgraded with you. now as you can see there back. My speed has HALVED in a month. Why is this please
<a href="http://s145.photobucket.com/user/85jamesjones/media/Mobile%20Uploads/2016-07/Screenshot_2016-07-31-1..." target="_blank"><img src="http://i145.photobucket.com/albums/r232/85jamesjones/Mobile%20Uploads/2016-07/Screenshot_2016-07-31-..." border="0" alt=" photo Screenshot_2016-07-31-16-02-31_zpsun7rroct.png"/></a>
Fixes: 165
Re: Speed issues AGAIN
Unfortunately I can't access those images to see what speeds they show. However testing your line isn't showing any problems at all. Are you testing over a wired or wireless connection? Can you try a single disconnect/reconnect and see what speeds you're seeing then.
 Chris Parr
 Plusnet Staff
Here you go Chris ..
