Speed - is this what I should expect?
Keymer
I'm struggling to understand the speed of my service and hope someone can help me. I don't know if the speed that I'm achieving is what I should expect, or if there is a problem somewhere.
I bought and set up a new router last week, after my old one had failed. The speed (as measured by the site speedtest.net) had been generally slow up to that point. With the new router the speed still appears to me to be too slow, although it does seem to fluctuate quite a lot. At the same time as replacing the router, I replaced the filters on the 2 phone extensions that I have.
Here's some more info:
BT Speedtester result:
Download speed achieved during the test was - 2119 Kbps
Additional Information:
Your DSL Connection Rate :6944 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 5000 Kbps
I am pretty sure that the IP profile has been higher than this before.
Recent Speedtest.net results
TEST_DATE DLOAD_MEGABITS UPLOAD_MEGABITS LATENCY_MS
10/02/2011 13:29 GMT 5.2 0.35 36
10/03/2011 18:42 GMT 1.51 0.38 48
10/03/2011 20:02 GMT 1.21 0.38 54
10/03/2011 20:56 GMT 1.47 0.38 48
10/06/2011 20:07 GMT 2.54 0.35 42
10/06/2011 21:10 GMT 6.1 0.38 38
10/07/2011 16:59 GMT 6.23 0.37 42
10/09/2011 08:05 GMT 4.02 0.36 42
10/09/2011 19:26 GMT 1.12 0.38 42
10/09/2011 19:30 GMT 0.9 0.38 51
10/09/2011 19:54 GMT 1.84 0.33 40
10/09/2011 21:09 GMT 3.42 0.37 38
10/10/2011 18:36 GMT 1.59 0.35 43
10/10/2011 18:59 GMT 3.4 0.38 36
10/10/2011 19:09 GMT 1.5 0.38 47
10/10/2011 20:11 GMT 2.19 0.34 59
10/10/2011 21:15 GMT 2.97 0.33 61
10/11/2011 18:17 GMT 1.52 0.33 45
10/11/2011 18:35 GMT 3.69 0.35 38
Router status
Downstream Upstream
Connection Speed    6944 kbps                          448 kbps
Line Attenuation 2      8.0 db                                  16.0 db
Noise Margin              10.8 db                                17.0 db
Multiplexing method – VC-Based
The  router has been on permanently for the last six days.
Any advice will be gratefully received.
1 REPLY
jojopillo
Re: Speed - is this what I should expect?
Hi Keymer,
Are these speeds via wireless or wired. Have a look at our help page and if it still continues, raise a fault.
Jojo Smiley
