Speed improvement?
Fixes: 382
Re: Speed improvment?
Good result - looks like @Baldrick1  was correct. 😀
Fixes: 480
@Rgmanby
Thanks for letting us know, it is appreciated. I see that the SNR has dropped to 3.1dB.
I suspect that overnight your hub firmware has updated to v10, which is currently being rolled out. That will have caused a reboot.
Rgmanby
Firmware version:
v0.08.00.08297-PN
is what it reports?
Fixes: 480
@Rgmanby
Ah, so it’s not yet updated. V10  is being rolled out (there is no v9 release) over the coming weeks. The update concerns minor issues unrelated to speed or security.
Rgmanby
Hi again,
just checked the logs again and it has updated to V10 on Wednesday, my speeds have slowed again though, is this another settling out period? I'd have thought a firmware update wouldn't have affected line speed etc though?Huh
See newest attachment taken.
Thanks.
Edit : router seems to have reset again around 3am this morning, must have been automatic as I was snoring!
Rgmanby
@jab1 @Baldrick1
Just an update on this, no improvement on speed since fireware update?
Seems to have stayed the same since the last post, why does it reset the line at 3am every morning?Huh
See attached screen grab.
Thanks again.
Fixes: 382
@Rgmanby Daily DSL drops just shouldn't be happening.Can you post your current WAN tab from the Hub, please?
Rgmanby
Not sure where to Find the WAN?
I did capture the following though showing system uptime and network uptime, it seems to do it every morning around 3am?Huh
Thanks.
Fixes: 382
OK, to make it easier, just post the exported .csv file you can get from Technical Log>Event Log. Might give us a clue.
Rgmanby
Hope tis right!
Thanks.
I edited log for just WAN on second file.
Fixes: 382
It is what I was after, thanks. Your DSL connection is failing every morning, as you say, but those logs suggest it is happening around 0200, not 0300.
@MatthewWheeler  - can you by any chance grab the RADIUS log for this customer, please?
Fixes: 382
@Rgmanby Thanks for the edited version, although I had filtered your original. 😀
Rgmanby
Thanks for your input, I'm still struggling to grasp why the firmware update slowed my speed, just after I'd got my speed back to where it was, sods law!
Cheers.
Fixes: 382
I don't think it was the f/w update that did that - there is obviously some instability on your connection which DLM is trying to compensate for by raising the SNR, but of more interest are the 'daily' DSL drops - which may (or may not) be related.
@jab1
you can ignore the two around these times
14:36:54, 05 Jul. System restart, reason: GUIReboot
14:37:47, 05 Jul. Upgrade and system start from GUI
23:33:38, 01 Jul. System restart, reason: GUIReboot
