Speed has gone from 20 to 12
TJ84
I recently had a new master socket plate fitted after raising a fault through plusnet. Speed was an unbearable 11-12mb and not even half a mb upload. New face plate did the trick and i had speeds in the very high teens early 20's aswell as 3-4mb upload which was like having FTTP such was the difference it made.
A month or so later the speeds have now fallen back to 12mb / 0.5mb and makes my gaming experience unplayable, and i cant understand what has happened?
I dont understand anything contained in the screenshot attached but hopefully it provides some clues.
Cheers
10 REPLIES 10
Fixes: 334
Re: Speed has gone from 20 to 12
@TJ84 Looking at that screenshot, you are on a very long copper run from your Fibre cab, but you do seem to be at the bottom of the expected range. Which Hub do you have, and can yo please run this test and report the results please:https://speedtest.btwholesale.com/
TJ84
Indeed, im about as far away from the cabinet as possible.
I have the Hub one router.
PING
29
ms
DOWNLOAD
12.22
Mbps
UPLOAD
0.55
Mbps
Fixes: 334
That doesn't look like the report I was expecting - see below for what I was. As I said, you are a long way from the cab, but your speeds are low.
TJ84
See attached, cheers
Fixes: 334
OK - that is clearer, thanks. It proves, to me, that your connection is not optimal. If you can wait until tomorrow morning, I will post some further help, but if you want to prod Plusnet in advance:
If the phone test passes, report a broadband problem via: https://www.plus.net/help/report-a-problem/broadband/
TJ84
Thanks John,
I sadly dont have a landline so cannot perform this test. I just dont undertsand how it was perfect for a month immediately after the installation of the new faceplate but has now suddenly reverted back to the stone age.
Fixes: 334
OK - no landline is unfortunate while you are on FTTC, as it is an essential tool. However, just use the broadband reporting option.
willcutforth
Fixes: 113
Hey there @TJ84 I can see an engineer has been booked out for you! Do you need anything else at the min?
 Will Cutforth
TJ84
Hi Will,
I'm not quite sure what an engineer visit will achieve to be honest as I only had one here last month to I stall the new MK4 faceplate. I have been told the engineer would possibly just be going to the green cabinet, so we shall shall see.
willcutforth
Fixes: 113
I'm hoping something can be achieved for you! Sometimes it takes a few to get to the bottom of the issue.
 Will Cutforth
