Speed has dropped over the last three month or so... reset possible?
Mewcenary
NOTE: I'm scheduled for switch to FTTP in a few weeks, so this may be somewhat redundant, but am curious as to what is happening...
I was regularly getting 59 Mbps 3 months ago.  This then dropped to 50 Mbps, and then to 46 Mbps which is where it has been sitting for the last two months.
I did suffer some line drops due to RF interference (This is due to non-broadband related equipment which has now been rectified).
Is there a way of forcing the line to attempt to scale up again?  As this doesn't seem to be happening automatically...
Thanks in advance,
Tristan.
4 REPLIES 4
Mewcenary
Re: Speed has dropped over the last three month or so... reset possible?
Download Test
Download speed achieved during the test was 41.22 Mbps
For your connection, the acceptable range of speeds is 40 - 47.38 Mbps
IP Profile for your line is 47.38 Mbps
Can I get the IP Profile increased again?
LaurenB
Fixes: 131
Hiya @Mewcenary, thanks for getting in touch. I'm sorry to hear you've experienced a decrease in your speed!
I've just reset your line for you and hopefully this will remove the banding, can you retest and let me know how things are?
 Lauren Barry
Mewcenary
Hi Lauren!
Thanks for this.  Here's the latest:
Download speed achieved during the test was 47.92 Mbps
For your connection, the acceptable range of speeds is 40 - 50.89 Mbps
IP Profile for your line is 50.89 Mbps
So, a small increase, but the IP profile about 10 Mbps shy of where it used to be...
adamwalker
Fixes: 223
Hi there, sorry it's taken us so long to check back in with you and it's good to see that there's been some improvement.
How are things looking at the moment?
 Adam Walker
