Speed has dropped off again
- Speed has dropped off again
25-02-2014 1:32 PM
Any chance of seeing if this line has become "banded" again?
Re: Speed has dropped off again
25-02-2014 2:22 PM
It does look like the line has been banded again. As the line has been stable for a long while, yet with a high SNR of 16.6db I've reset that so you should see some improvement in the next hour or so.
25-02-2014 2:40 PM
25-02-2014 4:26 PM
25-02-2014 7:48 PM
Click "Yes" on the red check-list, click "Begin Test" then after the initial test click "Further Diagnostics". Enter your phone number, then click "Run Diagnostic Test" and confirm the phone number is correct. Copy and paste the results in to a reply - something like this:
1. Best Effort Test: -provides background information.
Download Speed
11.75 Mbps
0 Mbps 21 Mbps
Max Achievable Speed
Download speedachieved during the test was - 11.75 Mbps
For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
IP Profile for your line is - 11.94 Mbps
Upload Speed
0.82 Mbps
0 Mbps 0.83 Mbps
Upload speed achieved during the test was - 0.82Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.83 Mbps
26-02-2014 1:30 PM
Here is the data that you requested:
Download Speed
1.95 Mbps
0 Mbps 4 Mbps
Download speedachieved during the test was - 1.95 Mbps
For your connection, the acceptable range of speeds is 1.2 Mbps-4 Mbps.
IP Profile for your line is - 3.58 Mbps
Upload Speed
0.34 Mbps
0 Mbps 0.45 Mbps
Upload speed achieved during the test was - 0.34Mbps
Upstream Rate IP profile on your line is - 0.45 Mbps
After the previous unbanding the figures were towards the upper limits of the ranges.
I hope this helps you.
P
26-02-2014 2:56 PM
Your line is syncing at 4055 with an internal profile of 3500. Was the Speed Test run via Ethernet?
26-02-2014 4:05 PM
I now see:
Download Speed
3.35 Mbps
0 Mbps 4 Mbps
Download speedachieved during the test was - 3.35 Mbps
IP Profile for your line is - 3.51 Mbps
Upload Speed
0.34 Mbps
0 Mbps 0.45 Mbps
A definite improvement in the download figures now (50% up on yesterday). Last time, Chris, you asked me to do a single router connect/disconnect to complete the job. See here: http://community.plus.net/forum/index.php/topic,120748.0.html do you wish me to do the same this time? Thanks.
P
26-02-2014 5:29 PM
27-02-2014 2:12 PM
21-09-2014 4:09 PM
Date Download Speed Upload Speed
Today 15:54 2458 kbps (307kB/s) 373 kbps (46.6kB/s)
Aug 20, 17:01 3015 kbps (377kB/s) 378 kbps (47.3kB/s)
Jul 12, 16:03 3627 kbps (453kB/s) 321 kbps (40.1kB/s)
it has been dropping off gradually since July. It would seem like the line has been banded again. Could someone see if they could "unband" this line - assuming that is the problem. Thank you. TheProfessor.
22-09-2014 12:25 AM
If this is happening repeatedly then it rather points to something being broken somewhere - most likely a bad line joint. Resetting the line us unlikely to deliver a long term resolution to this issue. I do hope there is no rein here, but that we can look at later.
Can you please post all of the information requested under the speed issues thread at the top of this forum.
Have you done a quiet line test?
Is the router in the master socket?
Does the master socket have a removable face plate? If yes please also post stars when connected there.
02-10-2014 4:17 PM
Sorry for the delay. I was out of the country at the time of your reply. I hope that this is the information that you were referring too:
Download Speed
2.27 Mbps
0 Mbps 4 Mbps
Download speed achieved during the test was - 2.27 Mbps
IP Profile for your line is - 2.29 Mbps
Upload Speed
0.38 Mbps
0 Mbps 0.45 Mbps
Upload speed achieved during the test was - 0.38Mbps
Further to your comments, I am not sure what you mean by "Quiet test". I believe that the router is in the master socket. The faceplate on the master socket is only detachable by removing the two screws in the plate. Additional: The line was originally installed around 1986/7 so all that is inside the socket is the capacitor and line protection device. Hopefully, Adam C will be arranging a BT visit in the next week or two.
I will attach any further comments to this thread.
Thanks for your reply.
P
02-10-2014 4:40 PM
The BT Wholesale speed and diagnostic test results reports BT Wholesale's view of your link, we also need to see the router's view (modem stats) and PlusNet's view (current speed). The full list of things required are to be found in here - http://community.plus.net/forum/index.php/topic,96155.0.html
In there you will find a link to the modem stats for the PN TG582n or a link to a site which tells you how to find the router stats. For the PN router the username is "admin" and the password is the serial number starting CP and is case sensitive.
Quiet Line test - dial 17070 option 2 - the line should be virtually silent. Any crackles or noises should be reported to your phone provider as a noisy line issue. Until such is fixed, you are not going to get a decent broadband service.
Kevin
02-10-2014 4:59 PM
In addition to the BT wholesale stat's above:
The (Netgear) router spec's are:
System Up Time 1032:32:54
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN PPPoA 3363154 5201061 0 3470 28776 31:03:42
LAN1 Link down 8211984 4635533 0 299743 60743 01:55:44
LAN2 Link down
LAN3 Link down
LAN4 100M/Full
WLAN b/g/n 300M 6396560 4251527 0 509508 95966 01:57:21
WLAN a/n 300M 0 0 0 0 0 01:57:14
ADSL Link Downstream Upstream
Link Rate 2595 Kbps 445 Kbps
Line Attenuation 47.5 dB 30.8 dB
Noise Margin 11.5 dB 23.9 dB
The Plusnet spec's history is:
Today 16:51 2183 kbps (273kB/s) 348 kbps (43.5kB/s)
Today 15:24 2220 kbps (278kB/s) 373 kbps (46.6kB/s)
Tuesday 16:20 2211 kbps (276kB/s) 361 kbps (45.1kB/s)
Sep 21, 15:54 2458 kbps (307kB/s) 373 kbps (46.6kB/s)
Jul 12, 13:58 3876 kbps (485kB/s) 339 kbps (42.4kB/s)
I hope that this is what you requested.
P
