Speed has dropped drastically following BT line repair
BertCoules
When my landline phone suddenly became extremely noisy a few days ago, I reported it to BT and had a visit from an engineer.  Apparently there was a problem with a cable (I'm not familiar with phone technology, so I probably have this all wrong) somewhere around the block from me.  "But I've switched you to the main cable" the chap said (after several hours work) "and you should be fine now".  "The main cable" is my half-remembered recollection of what he actually said: it's close, but not quite right.
He warned me that my internet speed might take some little time to stabilise and get back to normal, and that I would see some extreme fluctuations first.  Today, three days later, this hasn't yet happened: speeds have been and still are consistently well down.  The speed checker at http://www.speedtest.bbmax.co.uk/ reports 893 kbps download, 343 kbps up.  Before the problem, I was averaging around 3Mbps download speed.
The engineer said that if things didn't return to normal I should contact my ISP, "and they'll physically go in there and do something about it".  But I don't think he mentioned a timescale.  So how long should I wait before deciding that my old speed doesn't seem likely to return on its own?
Many thanks.
25 REPLIES 25
nozzer
Re: Speed has dropped drastically following BT line repair
Just to make you feel totally happy and contented, my line pair was changed at the end of September last year when the voice connection went down. It took until December to fix it, and that involved seven "engineer" visits and eventually a whole fresh new line!   Cheesy
Sounds similar to yours, the new line was showing a 90% throughput drop (although sync speed was the same as it had been). The guy who eventually fixed it reckoned that the first replacement line was picking up volts from somewhere.
BertCoules
Nozzer, thanks for that.  Maybe I should just be grateful that I still have a connection at all.
The thing that did stick in my mind was the engineer's assurance that if the broadband speed didn't pick up, "Your ISP will physically get in there and do something about it".  I have a vision of the super-techs of PlusNet descending en masse on my little town, screwdrivers and pliers in hand...
jojopillo
Hi BertCoules,
I'd pedal down on my pushbike but I'll check it out from this end first.
Jojo Smiley
BertCoules
Many thanks, Jojo.
(Just chain the bike to my front fence, it'll be perfectly safe.)
jojopillo
Hi BertCoules,
Hehe! Seriously, your sync rate is currently 1216k which is very poor for your line length. Are you using an extension cable/socket?
Jojo Smiley
BertCoules
Quote from: Joanne
No, I'm not.  And apart from whatever the BT engineer did outside (he didn't come into the house) nothing has changed in my setup at all.
Bert
jojopillo
Hi Bert,
Can you plug your filter directly into the test socket so I can run some more checks?
Jojo Smiley
BertCoules
Jojo,  Yes, I think I can, but it'll take a few minutes.  I'll post here when it's done.
Bert
jojopillo
Great, I'll hang around for you. Smiley
BertCoules
Jojo,
OK, that's done.  If it matters, the filter is a double one, with both my router and my phone plugged into it.
I just ran the online speedtest again and got a result very similar to the earlier one: 919/364.
Bert
jojopillo
Hi Bert,
You are definitely in the test socket behind the faceplate? If so then can you try a different filter  and if possible a different RJ11(the wire between the router and the filter)
Jojo Smiley
BertCoules
Quote from: Joanne
Hi Bert,
Yes, definitely.
If so then can you try a different filter...
OK, different filter now in place.  I don't believe I have a substitute RJ11 cable, unfortunately.  My online speed test is now reporting 915/335.
Bert
jojopillo
HI Bert,
That's still not made any difference. It would really help if you could borrow another router with an RJ11 cable.
Jojo Smiley
BertCoules
Sorry, duplicate post.
