Speed has disappeared.
rkid5846
Hi
I hope someone can help. On Thursday I moved my master socket. Since moving my speed had fell from high teens to less than one meg. I have replaced the master socket but it has made no difference.
I hope you can help, thanks.
6 REPLIES 6
Strat
Fixes: 565
Re: Speed has disappeared.
Has the phone been affected?
rkid5846
Haven't even got a home phone in the house, don't use one. Will get one tomorrow to test! What should I be looking out for?
Strat
Fixes: 565
You need to plug a corded phone into the master socket on its own and see if you have a working phone line.
MatthewWheeler
Fixes: 479
Your connection is currently on a banded profile which is why your speeds are so poor. This will probably be due to the drops shown below
I've done a reset which has increased the speeds but I'd recommend keeping a eye on it.
 Matthew Wheeler
rkid5846
Just back home and I'm getting 13MBPs on wireless, thanks for the help.
Can I ask what causes the connection to go to a banded status?
MatthewWheeler
Fixes: 479
DLM (Dynamic Line Management) will monitor your line and apply it if it sees any issues
The link below gives you more information if your interested.
http://www.kitz.co.uk/adsl/DLM_system.htm
 Matthew Wheeler
