Speed has been halved from normal - and regular disconnections
Buttercream
Not sure if this is the right place for this
For the past few years I've been getting a stable 50+ download and around 10+ upload connection. There was the odd disconnect here and there also but I put up with it. However, recently, I can't exactly say when it started, my speed has plummeted to half. I ran a test on speedtest.net a few times over the past few days, using a server in the closest city to me, and the results were consistently as follows:
27 DL / 4.8 UL / Download Latency; 120 / Upload Latency 95 - This is literally half of my usual
I've done the following things: I have tested on different computers to see if it was a driver issue. Same problem. I have tested different ethernet cables. Same problem. Both wired and wifi have the same problem. I do not have a different router to try. I do not have a different dsl/phone splitter to try. I have reset my router many times.
2 REPLIES 2
Fixes: 457
Re: Speed has been halved from normal - and regular disconnections
Moderator's note:
Post released from the automatic spam filter and moved from Full Fibre to Broadband
Fixes: 334
@Buttercream Please read and follow the below:
If the phone test passes, report a broadband problem via: https://www.plus.net/help/report-a-problem/broadband/
The above assumes you still have 'normal' landline connection - if you have a SOGEA (internet only) one the only option is to call Plusnet - 0330 123 9123
