Speed for country folk
- Speed for country folk
Re: Speed for country folk
25-07-2011 5:45 PM
Expect the line to fluctuate a little over the following 10 days as it settles down, but it certainly seems there is another satisfied customer.
B.
26-07-2011 8:59 AM
26-07-2011 11:04 AM
To be is to do - Kant
do be do be do - Sinatra
26-07-2011 11:32 AM
27-07-2011 3:21 PM
27-07-2011 4:23 PM
28-07-2011 10:11 AM
28-07-2011 10:23 AM
It's a load of rubbish.
This is mine and I have had a sync rate over 4500kbps for months
Estimated line speed:
1.5Mb (This may vary between 1Mb and 3.5Mb) - Checked on 2011-07-08 22:22:58
Current line speed:
4 Mb
28-07-2011 11:31 AM
01-08-2011 8:49 AM
Things seem to have settled to around 4.5Mbips
Would you please read the runes for me to see if things are progressing as expected
http://www.thinkbroadband.com/speedtest/button/131218473945785717857.png
Uptime: 1 day, 11:50:59
DSL Type: G.992.1 annex A
Channel mode: Interleave
Maximum Bandwidth (Up/Down) [kbps/kbps]: 988 / 6,016
Bandwidth (Up/Down) [kbps/kbps]: 448 / 6,016
Data Transferred (Sent/Received) [kB/GB]: 0.00 / 1.09
Output Power (Up/Down) [dBm]: 12.0 / 19.5
Line Attenuation (Up/Down) [dB]: 24.0 / 44.0
SN Margin (Up/Down) [dB]: 22.0 / 10.5
02-08-2011 10:00 PM
jim:green img tags added mod:end
03-08-2011 11:47 AM
03-08-2011 11:57 AM
Idealised speed throughput for a 44.0dB attenuation line is:
dslMAX 6,112 kbps, IP Profile 5,000 kbps, Throughput ~4,500Kbps
B.
03-08-2011 12:35 PM
http://www.skyuser.co.uk/forum/router-stats/14441-sky-router-stats-speed-noise-attenuation-explained...
http://www.kitz.co.uk/adsl/socket.htm
Glad that your speed has improved Peter.
Am going to check mine tonight and see if there is anything i can do to improve mine. Although i don't live in the country, i live in a pretty old house ~1900 and am unsure of the general quality of the wiring in the property, so wonder if this is having a negative impact. Now i know what to look for and what can be done about it.
03-08-2011 1:48 PM
Yes I live in an old house and the telephone wiring is pre 1981. When I started this thread we had set our our home office on the second floor (third floor in the US) at the end of some very dodgy wiring.
Now I have now moved my Thomson router to as near as I can to the incoming connection on the ground floor and I have netplugs to connect to our desktop in the office in the top of the building and a D Link router (without modem left over from when I had cable at another house and a single port modem) which I have positioned on the middle floor to provide Wifi.
I don't have a test socket and wonder where the noise is coming from. Would I have a claim on BT because the installation is so old and not fit for the modern age? Although I hear from other threads that new build have gone away from supplying test sockets again!
JoJo my implicit question is will my fundamentals change any more? SNR seems high and I understand should establish itself around 6. I had been moving my router downstairs for testing and back up to suit the family. But for the last three days I has stayed near the incomer and there it will stay. I am checking my speed and the Thomson report daily.
