Speed following line fault
- Speed following line fault
20-08-2013 12:00 PM
About 10 days ago we had a line fault (overhead cable down) repaired. Prior to the fault we generally had a sync speed of 2mb.
Since the repair, we seem to re-sync at about midnight or 6am on most days and the connection speed varies between 2240 and 2560. This has locked us into a sync speed of 1.75mb. We have gone back up to 2560 today.
Is there anything that will keep us over the magic 2272?. A 12.5% improvement/reduction is quite significant at these low speeds!
Message 1 of 4
(739 Views)
3 REPLIES 3
Re: Speed following line fault
20-08-2013 3:31 PM
Below is a graph of your recent connection:
<img src="http://community.plus.net/visualradius/generated/image13770089485919.png"/>
Is there anything that turns off/on in your house at midnight or 6am?
Message 2 of 4
(439 Views)
20-08-2013 6:19 PM
The only thing with a timer is the boiler which comes on at 7.00 and goes off at 22.30... Apart from that there's nothing.
Message 3 of 4
(439 Views)
21-08-2013 10:09 AM
I've just submitted an SNR reset which should hopefully bring the line profile back up for now but I fear that might drop again tomorrow so I'd urge you to raise a broadband fault: http://faults.plus.net
Message 4 of 4
(439 Views)
