Speed fault and phone fault
- Re: Speed fault and phone fault
26-04-2015 1:35 PM
Last person I spoke to at Plusnet said I would have to wait after the visit until Plusnet can give me a line reset ! Really fed up of this now.
27-04-2015 1:16 PM
27-04-2015 3:10 PM
28-04-2015 9:41 AM
28-04-2015 10:46 AM
It was a line engineer who came today and he thinks it is a broadband fault and he had no equipment to test the broadband. I did a speed test and it is still 12kbps!!
28-04-2015 10:53 AM
The engineer wasn't there to test the broadband though, he came to fix the fault. If you mentioned the slow broadband, he probably thought the job was incorrectly assigned and left believing another engineer was required.
I will check the notes shortly.
28-04-2015 10:58 AM
28-04-2015 11:08 AM
28-04-2015 11:14 AM
28-04-2015 11:23 AM
28-04-2015 11:27 AM
28-04-2015 12:03 PM
28-04-2015 12:19 PM
28-04-2015 12:38 PM
28-04-2015 2:22 PM
If so, is this only when the router is plugged in and on?
If yes to both, we need to get this back to a BT engineer for you (a broadband engineer).
If no, we need to look at the broadband fault
