Speed drops and DIY/electrical work, linked?
- Speed drops and DIY/electrical work, linked?
11-02-2013 6:18 PM
over the last few weekends ive been carrying out a bit of work on the household electrical system - nothing major, just replacing a few damaged sockets, adding double sockets in place of singles, and changing a few light fittings etc etc.
As i prefer to be safe I have been disconnecting the mains supply when required, and as a result my router is going on and off with the power.
However the following day my connection speed drops - ive tried re-booting my router ( turing it on/off ) but that has no effect, is this normal, and how can it be prevented?
Message 1 of 4
(933 Views)
3 REPLIES 3
Re: Speed drops and DIY/electrical work, linked?
12-02-2013 9:36 AM
There's no way to prevent this happening i'm afraid as it's the way broadband is intended to work. I.e speeds will drop if disconnections are seen.
However, I've submitted a line reset (SNR reset) which should hopefully return you back to normal speeds within a few hours.
Adam
Adam
Message 2 of 4
(459 Views)
13-02-2013 11:03 PM
Thnaks, ive just checked the conection settings/high speed broadband in the member centre/portal is this normal?
Estimated line speed:
14Mb (This may vary between 8Mb and 18.5Mb) - Checked on 2013-01-27 10:28:15
Current line speed:
6.7 Mb
Current line speed:
6.7 Mb
Message 3 of 4
(459 Views)
14-02-2013 11:50 AM
It look's like your profile has now bumped itself up, have you seen an increase?
Message 4 of 4
(459 Views)
