Speed dropped overnight
Kremmen
Fixes: 5
Morning
My internet speed has dropped overnight from ~24Mbps to ~11Mbps to 15Mbps in various checks
Can you have a look please.
I have had some manual disconnections a few days ago, that was me decorating.
Let's be careful out there !
3 REPLIES 3
Kremmen
Fixes: 5
Re: Speed dropped overnight
Update:
Further tests are now showing as low as 5Mbps !
I have rebooted my router and checked the speed on a Ethernet connected PC and a 5G connected Tablet.
Kremmen
Fixes: 5
...... and my 24Mbps speed has come back ~ 07:10
Kremmen
Fixes: 5
Update:
After investigation this turned out to be Microsoft Edge.
For some reason an update needed Edge as it wouldn't work via Opera. Edge held open a connection sucking up bandwidth.
I manually killed off the process and speed came back at that time.
