Speed dropped from 2.5 Mbps to 320 kbps
- Speed dropped from 2.5 Mbps to 320 kbps
24-01-2012 11:31 AM
I noticed a drop in speed this morning from 2.5 mbps to 320 kbps!
All wiring is OK and am plugged straight in the faceplate BT socket - no previous problems with speed.
I noticed that the noise margin was 25db and connection speed 512kbps. I rebooted the router and got the following results:
Suspect that IP profile is stuck - can you fix this the BT speed test shows 320 kbps
System Up Time 00:04:32
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN PPPoA 1800 2279 0 4794 12467 00:02:57
LAN 10M/100M 2492 2224 0 8805 3562 00:04:26 WLAN 11M/54M 0 0 0 0 0 00:00:00 --
ADSL Link Downstream Upstream
Connection Speed 3520 kbps 448 kbps
Line Attenuation 58.0 db 31.5 db
Noise Margin 5.8 db 20.0 db
Message 1 of 7
(1,679 Views)
6 REPLIES 6
Re: Speed dropped from 2.5 Mbps to 320 kbps
24-01-2012 11:42 AM
Hi scimitar,
I'll try an SNR reset on it and try to kick it into action.
Jojo
Jojo
Message 2 of 7
(835 Views)
24-01-2012 11:54 AM
Dear JoJo
I hope this works however if the IP profile is stuck at 500kbps am I right in saying that it will take 72 hours for the IP proifle to go higher?
Regards
Scimitar
Regards
Scimitar
Message 3 of 7
(835 Views)
24-01-2012 12:09 PM
Test1 comprises of Best Effort Test: -provides background information.
Download Speed
Dear JoJo
BT Speed Tester Results are as follows:
0 Kbps 500 Kbps
Max Achievable Speed
Download speedachieved during the test was - 371 Kbps
For your connection, the acceptable range of speeds is 50-500 Kbps.
Additional Information:
Your DSL Connection Rate :3648 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 350 Kbps
Download Speed
Dear JoJo
0 Kbps 500 Kbps
Message 4 of 7
(835 Views)
24-01-2012 1:20 PM
Hi scimitar,
It can take 72 hours for the profile to lift. This can be shorter, depending on how big the increase is. The SNR reset should get it back up to speed though.
Jojo
Jojo
Message 5 of 7
(835 Views)
25-01-2012 8:36 AM
Dear JoJo
All is back to normal now - speed 2.6mbps with SNR at 6.5. I do have a long line to the exchange in a rural area so I am happy with the connection.
Thank you for your speedy response in resolving this. The support given on this forum is excellent - well done.
Regards
Scimitar
Regards
Scimitar
Message 6 of 7
(835 Views)
25-01-2012 9:01 AM
Hi Scimitar,
Thanks for letting me know. Glad we could be of service.
Jojo
Jojo
Message 7 of 7
(835 Views)
