Speed drop to ~24Mb/s
- Speed drop to ~24Mb/s
11-03-2026 5:22 PM
Have recently noticed some issues with speed on my connection.
Was connecting reliably at 65+Mb/s for several years but seems to have dropped to between 25 and 30 Mb/s
See screenshots from speed test and Hub tech log
Message 1 of 2
(238 Views)
1 REPLY 1
Re: Speed drop to ~24Mb/s
12-03-2026 9:11 PM
@tgswales looking at the Hub data page you have posted, I would suggest you have a fault, most likely in the Openreach network. Suggest you try reporting an issue via: https://www.plus.net/help/report-a-problem/
Message 2 of 2
(175 Views)
