Speed drop since the massive outage of a few days ago.
- Speed drop since the massive outage of a few days ...
01-11-2010 4:33 PM
Hello all.
Up until the massive broadband outage a few days ago, my router had been steady for 35 days and synced at over 7000 (my profile was 6000).
Unfortunately since everything went back on line my router has now synced at about 5500. Every 24 hours I have done a reset to try and force it back to where it was pre outage. I have had no joy. My line attenuation has remained at a low 22db but my SNR is higher than it was pre outage.
My router stats are currently;
Link Information
Uptime: 0 days, 3:57:43
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 5,664
Output Power (Up/Down) [dBm]: 12.0 / 19.5
Line Attenuation (Up/Down) [dB]: 11.0 / 22.0
SN Margin (Up/Down) [dB]: 21.0 / 12.5
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Link (Remote): 0
FEC Errors (Up/Down): 0 / 417
CRC Errors (Up/Down): 0 / 0
HEC Errors (Up/Down): 0 / 0
Is there any way to get my sync rate back to where it was pre outage, and therefore my profile and download speed back up.
Thanks in advance.
Link Information
Thanks in advance.
Message 1 of 5
(855 Views)
4 REPLIES 4
Re: Speed drop since the massive outage of a few days ago.
01-11-2010 4:40 PM
Ask for a noise margin reset
Message 2 of 5
(423 Views)
01-11-2010 5:02 PM
Hi moffat2000,
I could do What Jim suggests if you like. You would have to go back into the training period though.
Jojo
Jojo
Message 3 of 5
(423 Views)
01-11-2010 5:07 PM
Hi Jojo,
If you could do the reset that would be great. I'll ride out the training period and see what happens.
Many thanks.
Many thanks.
Message 4 of 5
(423 Views)
01-11-2010 5:35 PM
Hi moffat2000,
I've just requested that. I'll check from home later and let you know how it went.
Jojo
Jojo
Message 5 of 5
(423 Views)
