Speed drop outs
campinggaz
Speed drop outs
There has been loads of speed drop outs not able to stream at a decent pixel rate absolutely shocking been going on for a while
3 REPLIES 3
Fixes: 387
Re: Speed drop outs
@campinggaz Do  you mean disconnections and/or speed reductions? A little more detail would enable us to give you some advice.
campinggaz
Re: Speed drop outs
yes and variations in speed,
Fixes: 387
Re: Speed drop outs
In that case:
BTW Performance Tester - Over a wired (Ethernet) connection if at all possible, please report the 'ADDITIONAL DIAGNOSTICS'- if it will run. This test is recommended to be performed with only one device connected.
For the Hub One -
For the Hub Two -
