Speed drop - broadband unusable
- Speed drop - broadband unusable
Re: Speed drop - broadband unusable
20-10-2014 7:44 PM
Quote from: Pedro21 I have tried all the options that I know off, 2 routers, 4 microfilters, two different telephones (digital and analouge) main socket connection and the test socket behind the face plate. The line was a bit more stable but very slow (0.16dl 0.37ul) on Saturday 18th October
Remember that even if changing something fixes whatever is causing the issues you will not see an immediate improvement in speeds. So when for example using the test socket you need to leave it for a day and see if it stops the disconnects. You should also test if using the phone still causes a problem. If it appears better, i.e. the disconnects have stopped, Plusnet can have the line reset and only then will you see improved speeds.
20-10-2014 7:57 PM
@ jelv, I went through this same problem mid August, not quite as bad we at least had a connection of sorts, this time its up and down like a jack in the box on speed. I have tried both router in the test socket for 24hrs each. The problem is trailing cables across door ways, not that I care much for health and safety, but with older parents around its better to be safe than sorry. Last time it took about 3 days for the speed to increase back to normal.
Regards
Peter
20-10-2014 10:14 PM
Quote from: Pedro21 The problem is trailing cables across door ways
Was that power and Ethernet or just Ethernet?
20-10-2014 11:14 PM
Thank you for the graphs, they are VERY useful. With out any fear of contradiction, you have really bad REIN coming from somewhere. The router stats graphs show a horrible story.
Explanation: when SNRM is higher REIN is reduced, when SNRM is lower, REIN is more prevalent.
Can you correlate any DOWNWARD shift with anything being switched on (or coming out if standby) or UPWARD shift (not associated with a resynch) with anything being switched off (or going into standby).
REIN fits in well with these plots and no fault being found on the phone line.
This is likely to take some time to bottom out. Please keep the plotting running 24x7 and we are going to need to look for reoccurring patterns and times.
Edit: Just remembered I've seen patterns like this before - see http://community.plus.net/forum/index.php/topic,125789.msg1103047.html#msg1103047 - when you see the defending plot, can you please just pick up your phone and put it down again. I'm interested in knowing if SNRM recovers just as did Uncle_Meats's.
Kevin
21-10-2014 6:45 AM
21-10-2014 8:59 AM
The routers are in the same position that they always have been ever since we got broadband through Plusnet.
It does seem strange that the problems occurred after heavy rain.
On Saturday (18th October) when we had a connection picking up either phone would drop the DSL connection and it would take around 20 minutes to recover.
I will need to set the Routerstats recording tonight as I am back at work right now (with as nice 76Mb line, also with Plusnet), with an understanding boss who lets me use it without to much concern, joys of long service ;D.
@jelv whilst plugged into the test socket there was no connection at all, it was just an ethernet cable, I will need to route around the door when I finally switch to FTTC once this is resolved.
21-10-2014 9:05 AM
I've updated your ticket along the lines of the information provided yesterday. Basically, with the information that we got yesterday, and the testing already done (assuming advice followed here has been followed) we can progress.
Tony
21-10-2014 9:06 AM
21-10-2014 9:19 AM
Thanks for that, I have just got the text for arranging an Engineers visit, I will check with the folks at home tonight and come up with 3 dates, can I post them here or do I need to respond to the text.
@jelv, homeplugs would be ideal, unfortunately the mastersocket is some 3metres away from the nearest plug socket.
21-10-2014 9:23 AM
21-10-2014 7:23 PM
Any day next week will be okay, prefer 8am to 1pm. Gives me a chance to warn the boss about working from home again
22-10-2014 3:22 PM
22-10-2014 3:30 PM
Yep, Engineer visit booked to next Monday morning, hopefully he finds the problem.
Thanks for all your help, will be looking to switch everything over to Plusnet in the next month or so and upgrade to fibre
Regards
Pedro
22-10-2014 4:55 PM
27-10-2014 3:00 PM
Bad news I'm afraid
The Engineer left around 14:00 hours having spent the best part of 3 hours trying to trace the fault. He did find a fault on the line from the house back to the cabinet but not the other way. He then tried to switch lines and must have been up and down the nearest drop pole 5 times, he even tried the next pole down the road. Unfortunately there are no spare lines and he was going to report it to the underground team as the problem is between the cabinet and where it rises up to the pole. At least this Engineer spent good time on the fault and did not just report it as a 'ghost fault' like the last one, he is even thinking of reporting the last job as unsatisfactory.
Where doe this leave us, as we are paying for broadband that we are not getting and how long with it take for BTOR to send an underground team out ?, this is also causing some concern over switching to FTTC.
Regards
Peter
