Speed drop after roadworks
- Speed drop after roadworks
21-05-2014 9:35 AM
A few months back all the street lights were replaced on the road I live on. Prior to this my speed was consitant at nearly 3 mbps. During the roadworks the speed varied widely. Now, a few months after the work being completed my speed is consistant a 2.1 mbps. The phone wires are under the pavement and run parallel to the street light wiring. Is there a fault or is this now the best speed available?. Thanks
DSL Connection
Link Information
Uptime: 2 days, 9:44:57
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 2,688
Data Transferred (Sent/Received) [kB/kB]: 0.00 / 295.00
Output Power (Up/Down) [dBm]: 12.5 / 17.5
Line Attenuation (Up/Down) [dB]: 29.5 / 49.0
SN Margin (Up/Down) [dB]: 13.0 / 10.0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 1,371 / 0
FEC Errors (Up/Down): 0 / 335,200
CRC Errors (Up/Down): 0 / 5,958
HEC Errors (Up/Down): 0 / 4,337
FAQ
Results Image not loaded
1. Best Effort Test: -provides background information.
Download Speed
2 Mbps
0 Mbps 4 Mbps
Max Achievable Speed
Download speedachieved during the test was - 2 Mbps
For your connection, the acceptable range of speeds is 1.2 Mbps-4 Mbps.
IP Profile for your line is - 2.4 Mbps
Upload Speed
0.18 Mbps
0 Mbps 0.45 Mbps
Upload speed achieved during the test was - 0.18Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.45 Mbps
Estimated line speed:
Current line speed:
2.3 Mb
DSL Connection
Link Information
FAQ
Download Speed
2 Mbps
0 Mbps 4 Mbps
Upload Speed
0.18 Mbps
0 Mbps 0.45 Mbps
Current line speed:
2.3 Mb
Message 1 of 3
(526 Views)
2 REPLIES 2
Re: Speed drop after roadworks
21-05-2014 9:47 AM
Hi bumbershoot,
I've just shifted your SNR Target back from 9db to 6db which should see you gain a little speed. I've updated all the necessary speed profiles too.
You should notice an improvement within the next 4 hours.
Message 2 of 3
(310 Views)
21-05-2014 10:03 AM
Very quick response . Thanks.
Message 3 of 3
(310 Views)
