Speed down FTTC
G3YBO
Speed down FTTC
Hi.............My speed has gone down over last week ?    No changes on my side of the wire.....
Re: Speed down FTTC
Hi G3YBO,
I can see that your sync speed has dropped slightly. I'd suggest trying a soft disconnect via logging into your routers interface and clicking disconnect, then power down your router and modem and leave powered off for a few minutes. Firstly power on your modem and wait for your DSL light to go stable and then power on your router and click connect in the routers interface.
Test your speeds again and see if there is any difference,
G3YBO
Re: Speed down FTTC
Hi Chris.........I have done as you asked but seems still to be down.....
Roger
Re: Speed down FTTC
There's nothing obvious why your speeds have gone down. I'd suggest running through the checks at http://faults.plus.net and is it's still the same then this will formally raise a fault with us to investigate.
G3YBO
Re: Speed down FTTC
Ok Chris......Have done the test that you asked for.......Thanks.........Roger
Re: Speed down FTTC
That's with our faults team now, as soon as they have completed testing they'll be in-touch.
