Speed difference
- Speed difference
Speed difference
08-08-2013 1:14 PM
BT openreach have just done some work outside my house. My estimated speed is showing 58MB but my current speed is showing 67.8 shouldn't both values be the same? I'm worried I'm going to be throttled back to 58. Do PN need to do a profile change?
Message 1 of 6
(730 Views)
5 REPLIES 5
Re: Speed difference
08-08-2013 1:17 PM
ignore the estimated speed, that won't change from when you signup
"current speed" on PN should match line profile at BTW - http://speedtest.btwholesale.com/
Message 2 of 6
(378 Views)
08-08-2013 1:23 PM
Ip profile shows 74.19 (higher than expected). So no match there. Seeing as its higher do plusnet need to adjust my profile?
Message 3 of 6
(378 Views)
08-08-2013 1:51 PM
Just reran the btw test and my profile is set at 74.19MB and Plusnet is reporting as 67.8MB. Can someone from PN confirm if my PN profile needs adjusting?
Message 4 of 6
(378 Views)
08-08-2013 4:03 PM
Hi, sorry I'd not got to this post yet - got your PM though, hope things are sorted for you?
Message 5 of 6
(378 Views)
08-08-2013 4:04 PM
current speed now matches the IP profile. I'm on my laptop at the moment so can't do a proper speed test (seems to show a bit slower, even on Ethernet)
Message 6 of 6
(378 Views)
