Speed difference between iPhones and Macbooks
mrandrewstewart
Getting a bit of an odd problem, I'm getting approx 35mb/s download speed through the phones and tablets in my house but approx 2mb/s on the two Macbooks (both through WiFi and Ethernet)
Any idea what could be wrong? I was getting similar speeds for all a few days ago but had a massive drop over the weekend. Not made any changes anywhere!
These were taken about 30 seconds apart:
Gazzertron
Re: Speed difference between iPhones and Macbooks
If you look at the 'graph' below your mobile download you will see that most of the test your download was low, with a high speed spike at the end.
They don't give you an average, just the highest speed attained (which could be just for one second).
Gary
mrandrewstewart
Ah right, thanks. We'll this changes to another moaning about speed thread then!
