Speed difference after moving from BT
antireality
About a month ago I was using an unlimited BT ADSL packaged on the very same line I'm using for plusnet now, and I had been getting a consistent 13mbit/sec connection. After moving to plusnet it's dropped down to 8mbit/sec. I would've thought that given that everything else is the same that I'd have gotten more or less the same speed as before after changing.
Is there anything I (or anyone else) can do to improve this at all?
1 REPLY
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: Speed difference after moving from BT
Hi antireality,
I've just placed an order to change the product you were provisioned on. You should see an improvement within the next 24 hours.
Chris Pettitt
Cloud Environments Engineer
