Speed deterioration
- Speed deterioration
Speed deterioration
21-02-2014 1:50 PM
I have been enjoying decent speeds for some time but during the gales everything has about halved. No changes to kit or anything else. Has BT /OR been up to something?
Belkin N Router (wired). Down Data Rate. Noise Margin. Atten . Up Data Rate Noise Margin Atten.
04.01.14 7616Kbps 8db 38db 448Kbps 24db 21db
until 05.02.14 7104Kbps 10db 38db 448Kbps 23db 22db
until 12.02.14 6464Kbps 9db 39db 448Kbps 23db 22db
until 13.02.14 7104Kbps 7db 38db 448Kbps 24db 21db
until 14.02.14 3808Kbps 20db 39db 448Kbps 17db 22db
Now 21.02.14 Continuing as above.
Any ideas?
Any ideas?
Message 1 of 4
(1,045 Views)
3 REPLIES 3
Re: Speed deterioration
21-02-2014 3:50 PM
Quote from: colintivy
That's a fairly large jump from previous readings. Do a few more tests and see if the noise stays the same. If not run the noise test here http://support.zen.co.uk/kb/Knowledgebase/Performing-a-Quiet-Line-Test and have a listen if there is noise on the line, Go from there mate.
Good luck.
Blinky
Message 2 of 4
(426 Views)
21-02-2014 4:55 PM
Power down your router at around 10.00am tomorrow morning and then power it up twenty minutes later, check the router stats straight away.
Do a BTw PerformanceTest all the way through i.e. diagnostics etc and check sync and IP profile > http://speedtest.btwholesale.com/
Check the line speed/PN profile in the PN member centre, in other words login to the portal and go here
> https://portal.plus.net/my.html?action=data_transfer_speed to find the current PN line speed.
Message 3 of 4
(426 Views)
23-02-2014 11:21 AM
Thanks lads, Powered up today and what did I find?........................
23.02.14 10.53 Download Data Rate 5856Kbs Noise Margin 2db* Atten 41db!!! *never seen it that low before.
Nothing fiddled with here, no evidence of OR bodies down holes or up poles!! Weather wet and windy as well. QLT like a grave.
Done BT Wholesale test:
Download speed 2.92Mps. Acceptable Range for connection 0.6 to 7.15 Mps. DSL Connection Rate 5.86 **Mps. IP Profile 3 Mps. ** Belkin always agrees with this.
Looks like a tweek of Profile is needed. I do not like the figures for Acceptable Range, very broad.
Message 4 of 4
(426 Views)
