Speed decrease again :(
- Re: Speed decrease again :(
28-07-2013 2:10 PM
I'd really like this fixed....along with the disconnections. It's sometimes fine for days then last night about 5 disconnects.
Download speedachieved during the test was - 20.87 Mbps
For your connection, the acceptable range of speedsis 16 Mbps-21.68 Mbps .
Additional Information:
IP Profile for your line is - 21.68 Mbps
Upload speed achieved during the test was - 4.46Mbps
28-07-2013 2:17 PM
29-07-2013 5:06 PM
@udk I've been running a few checks and can't see anything obvious so you'd be best raising a fault with us re that: http://faults.plus.net
@albinocory, I can see we recently looked at this for you from a faults perspective. I'd advise running another test at http://speedtest.btwholesale.com as suggested on the last fault ticket and raise that again by the faults link I've given udk above.
Adam
29-07-2013 6:10 PM
29-07-2013 6:33 PM
@albino, did you use it recently already? I think you need to wait a bit between using it
30-07-2013 7:41 AM
@adam walker to be honrst its a waste of time going a faults ways as already had OR out 4 or 5 times out already they say its ok but 1 of them said all he can think off that its the copper wire that's degraded but they wont put a new one in the way its going we may have to go back to asdl cos its more stable the fttc
01-08-2013 2:03 PM
I've just had openreach engineers out and they've replaced all the outside cabling and performed a DLM reset, so back up to what I started
Download speedachieved during the test was - 20.83 Mbps
For your connection, the acceptable range of speedsis 16 Mbps-40.91 Mbps .
IP Profile for your line is - 40.91 Mbps
01-08-2013 5:22 PM
01-08-2013 5:30 PM
Is there something I need to do?
01-08-2013 6:22 PM
