Speed and router problems :(
egirl
So I've been a customer for a month now.
My speed started dropping yesterday and this morning I couldn't get wifi at all on any of my devices (phone, ipod etc)
It kept diverting me to the log in page for the router that was supplied by plusnet.
I have now managed to get online but my speed is ridiculous! Current reading is 0.68Mb download and 0.027Mb/s upload.
Any ideas what the problem is? I usully get seed of about 4.6Mb/s
thanks
Fixes: 62
Re: Speed and router problems :(
Please provide the full router stats as asked for here http://community.plus.net/forum/index.php/topic,96155.0.html
egirl
DSL Connection
Link Information
Uptime: 0 days, 4:47:37
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 35 / 4,779
Data Transferred (Sent/Received) [MB/MB]: 6.24 / 59.20
Output Power (Up/Down) [dBm]: 11.3 / 0.0
Line Attenuation (Up/Down) [dB]: 32.4 / 54.5
SN Margin (Up/Down) [dB]: 20.9 / 8.7
Loss of Signal (Local/Remote): 4 / 0
Loss of Link (Remote): -
Error Seconds (Local/Remote): 1,961 / 3
FEC Errors (Up/Down): 68,911 / 2,238,781
CRC Errors (Up/Down): 1,613 / 20,974
HEC Errors (Up/Down): 441 / 174,638
Fixes: 62
Is there any noise on the line - dial 17070 option 2
Basically your upstream speed is shot to hell and this is crippling your downstream speed from a speed test
You need to resync the router - click on disconnect from http://192.168.1.254/cgi/b/bb/?be=0&l0=2&l1=-1 then unplug it from the phone line once the internet connection light has turned red
Once the DSL light has gone red/flashing plug it in again and once it goes green click in connect from the same link
What are the new stats
egirl
Thanks for your response.
No noise on the phone line,
I did as you said with the router but my lights never went red...waited ages. I then had to disconnect the router as it wasn't accepting the 'admin' and password I was putting in when I tried to go back in to connect.
new stats
DSL Connection
Link Information
Uptime: 0 days, 0:01:49
DSL Type: ITU-T G.992.3
Bandwidth (Up/Down) [kbps/kbps]: 444 / 5,388
Data Transferred (Sent/Received) [kB/MB]: 217.43 / 1.23
Output Power (Up/Down) [dBm]: 12.6 / 0.0
Line Attenuation (Up/Down) [dB]: 31.7 / 51.0
SN Margin (Up/Down) [dB]: 16.8 / 6.2
Error Seconds (Local/Remote): 3 / 0
FEC Errors (Up/Down): 0 / 312
CRC Errors (Up/Down): 5 / 9
HEC Errors (Up/Down): 24 / 154
egirl
new speed test  Smiley http://www.speedcheckerapi.com/Images/150439061.jpg
thanks for your help. Hope it stays like this  x
Fixes: 62
That has fixed the immediate problem but not what caused the upstream speed to drop to that extent
You will need to monitor what is happening
I suggest installing Routerstats http://www.vwlowen.co.uk/internet/files.htm
Could do better - it's on ADSL2 (G.992.3) instead of ADSL2+ (G.992.5). Your upstream is capped, and the error count is fairly high for just over a minute connected.
If you have the appropriate telephone socket, try connecting to the test port, to rule out any internal wiring issues. See the guide here https://www.plus.net/support/broadband/master-socket-guide.shtml.
Fixes: 62
That is a very good speed for a 51dB attenuation and as such won't see any benefit from being on ADSL2+
Upstream should remain capped until we find out what caused the problem in the first place
Initial errors on connection aren't a reliable indication of anything. We need to see what happens over a few hours
egirl
I'm not very technology savvy...so I will have a go at downloading the routerstats and see how I get on...
thanks again for helping, I really appreciate it.  Smiley
