Speed and Interleaving
- Speed and Interleaving
19-09-2009 5:43 PM
My broadband speed over the last few months seems to have been getting worse, and is very intermittent especially when gaming.
I have ran a few tests, both with your tester, and also BT's. Here are the results:
BT:
Download speedachieved during the test was - 2173 Kbps
Additional Information:
Your DSL Connection Rate :2944 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 2500 Kbps
YOURS:
Today 17:41 2308 kbps (289kB/s) 377 kbps (47.1kB/s) Share
Yesterday 17:28 2476 kbps (310kB/s) 376 kbps (47kB/s) Share
Thursday 18:36 2290 kbps (286kB/s) 369 kbps (46.1kB/s) Share
Thursday 18:36 2518 kbps (315kB/s) 377 kbps (47.1kB/s) Share
Thursday 18:35 2270 kbps (284kB/s) 377 kbps (47.1kB/s) Share
Thursday 18:35 2821 kbps (353kB/s) 377 kbps (47.1kB/s) Share
Thursday 18:34 2726 kbps (341kB/s) 368 kbps (46kB/s) Share
Thursday 18:33 2224 kbps (278kB/s) 368 kbps (46kB/s) Share
Aug 25, 15:08 1952 kbps (244kB/s) 274 kbps (34.3kB/s) Share
Jul 21, 17:36 2167 kbps (271kB/s) 358 kbps (44.8kB/s) Share
Oh by the way, my router stats are:
Type Interleave
Status No Defect Available
Downstream Upstream
Data Rate(Kbps)
2912 448
Noise margin (dB)
9.3 17.0
Output power (dBm)
17.6 12.3
Attenuation (dB)
57.0 31.5
And it is also showing that interleaving is turned on?
Nothing has changed, using the same router into the same socket, using the same filters etc. Is there anything that can be done?
Of course I started a ticket, but I just got the usual response..."In order for us to look further into this please visit http://faults.plus.net", done this but now the BT speed checker doesn't work?
As said previously, is there anything that can be done, and also could interleaving be turned of please? By the way, i pay £20 p/m for 2mb!!!
Regards,
Craig Richards
Re: Speed and Interleaving
21-09-2009 4:05 PM
The noise margin could be slightly better, but not much. I don't think removing interleaving will make much difference for your speed.
21-09-2009 8:11 PM
Thanks for getting back to me. I removed the ring wire from my socket, and the router stats are now as follows:
Data Rate(Kbps)
3072 448
Noise margin (dB)
8.0 17.0
Output power (dBm)
18.1 12.3
Attenuation (dB)
57.0 31.5
Would turning interleaving help with gaming? I always seem to get lag on the PS3 (Hard Wired by the way)?
Thanks,
Craig
21-09-2009 8:24 PM
Sorry, meant to mention this but forgot. Most of the trouble I have is in the early/evening/night, through until around midnight, then things tend to get better. For instance now, browsing seems to be very very slow, with pages hanging now and again?
Craig
22-09-2009 9:40 AM
Does your router give you any indication of any errors? That would help with working out whether or not interleaving would help at all.
What sort of speedtest results do you get when the connection is feeling a bit on the slow side?
22-09-2009 2:16 PM
Router shows no errors, well for what I can find anyway?
Did some test's last night and got the following, even though the browsing was hit and miss for most of the night.
Today 14:13 2445 kbps (306kB/s) 377 kbps (47.1kB/s) Share
Yesterday 21:25 2564 kbps (321kB/s) 376 kbps (47kB/s) Share
Yesterday 21:24 2592 kbps (324kB/s) 377 kbps (47.1kB/s) Share
Yesterday 21:24 2709 kbps (339kB/s) 369 kbps (46.1kB/s) Share
Yesterday 20:08 2555 kbps (319kB/s) 363 kbps (45.4kB/s) Share
Yesterday 20:08 2589 kbps (324kB/s) 365 kbps (45.6kB/s) Share
Saturday 17:51 2376 kbps (297kB/s) 377 kbps (47.1kB/s) Share
Saturday 17:41 2308 kbps (289kB/s) 377 kbps (47.1kB/s) Share
Friday 17:28 2476 kbps (310kB/s) 376 kbps (47kB/s) Share
Even though the speed doesn't look all that bad, the actual connection on an evening is terrible, and online game play is just as bad, had to turn the PS3 of last night due to lag being that bad.
As you can see from the test's above, my connection is never steady? I would have thought it would be?
Thanks,
Craig
22-09-2009 2:19 PM
Those tests are actually fairly steady for a contended broadband service.
It might be an idea to try configuring your rWin & MTU settings where possible - may make a difference.
http://www.plus.net/support/broadband/troubleshooting/rwin_guide.shtml
22-09-2009 2:23 PM
though I have set the router and ps3 to use the same mtu
22-09-2009 2:29 PM
22-09-2009 3:24 PM
With regard to the account query, the account type doesn't have any effect on the line speed - that's all between your premises and the exchange so if that's why you were thinking of changing you won't see any difference.
I'll have a look for something RWIN/MTU-like on the mac and post back if I have any luck.
22-09-2009 3:27 PM
I have managed to calculate & also change the MTU for OS X to 1478, so set this for both OS X and the router, plus the PS3. Ran a couple of speed test's and no different, but will check again tonight.
Thanks,
Craig
