Speed and BT Speedtest profile
- Speed and BT Speedtest profile
10-10-2011 4:33 PM
Hi
I've just run a BT speedtest, it reports my profile at: 9902 Kbps however the Plusnet Stable Rate page says: Current line speed: 7.15 Mb
Is there a reason for this difference?
Overall I'm happy with the speed of my service, I've recently been moved to ADSL2+ from Max DSL to increase my upload speed and have been more concerned with disconnections (average once a day) than achievable speed.
I've attached some stats:
--------------------------- ATU-R Info (hw: annex A, f/w: annex A) -----------
Running Mode : ADSL2+(G.992.5) State : SHOWTIME
DS Actual Rate : 11224615 bps US Actual Rate : 1248983 bps
DS Attainable Rate : 13984000 bps US Attainable Rate : 1248000 bps
DS Path Mode : Interleave US Path Mode : Interleave
DS Interleave Depth : 96 US Interleave Depth : 1
NE Current Attenuation : 29 dB Cur SNR Margin : 9 dB
DS actual PSD : 20. 4 dB US actual PSD : 12. 6 dB
ADSL Firmware Version : 2471201_A
-------------------------------- ATU-C Info ---------------------------------
Far Current Attenuation : 14 dB Far SNR Margin : 6 dB
CO ITU Version[0] : 00004946 CO ITU Version[1] : 0000544e
DSLAM CHIPSET VENDOR : < IFTN >
Message 1 of 4
(890 Views)
3 REPLIES 3
Re: Speed and BT Speedtest profile
10-10-2011 4:59 PM
Hi nebula,
I've changed that for you now. You should see the increase in the next 15 minutes.
Jojo
Jojo
Message 2 of 4
(406 Views)
21-10-2011 12:13 AM
Hi, many thanks for looking at my connection.
I've completed internal and external re-wiring combined with isolation tests and managed to achieve a stable connection. Not sure if my efforts have affected my profile as I've disconnected multiple times to try various combinations; at your end my profile now reads: 'Current line speed: 8 Mb'
BT Speedtest reports: 11195 Kbps (attached)
SNR is low, 3 at night and up to 10 in the day -- highest I've ever seen so rewiring has at least made some improvements!
Is there anything else I can do to stabilise my profile?
DS Actual Rate : 12690468 bps US Actual Rate : 1294222 bps
DS Attainable Rate : 12320000 bps US Attainable Rate : 1296000 bps
DS Interleave Depth : 64 US Interleave Depth : 4
NE Current Attenuation : 28 dB Cur SNR Margin : 3 dB
Message 3 of 4
(406 Views)
21-10-2011 6:45 AM
I get a similar result to you with the BT test using WiFi, but it is a lot higher using Ethernet.
The PN myspeedtest doesnt seem to care if it is WiFi or ethernet,
Message 4 of 4
(406 Views)
