Speed Thread (Before and after transfer speed comparisons)
- Speed Thread (Before and after transfer speed comp...
Re: Speed Thread (Before and after transfer speed comparisons)
02-12-2008 6:31 PM
What is missing is any reference to this arrangement in the main link:rules, guess what I get to do this weekend
02-12-2008 11:32 PM
03-12-2008 5:44 PM
03-12-2008 6:08 PM
Quote from: ASBO santa's coming tomoro then word warrior can't wait to see what the sync increases are like on the adsl under 4000kbps lines every kbps is well needed in this area
The only thing is.....
I'm having to go to a job in Ipswich tonight and I won't now be back till late tomorrow night (I'm guessing 21.00 - 22.00 at best) Probably be too tired to switch off modem and on again and so forth so you guys will have to wait for an update.
Thanks for your interest Asbo dog
Of course the change might not happen until late anyway.
Will keep you posted.
03-12-2008 9:50 PM
04-12-2008 11:20 AM
Sync 3392 down 736 up Att 59.5dB S/N 9.8dB (forced)
BRAS 2500
Speed test 2314 down 619 up
After 21CN (today)
ADSL2+ forced with DMT tool
Sync 3782 down 600 up Att 60db S/N 9.6db (forced)
Speed test 2333 down 509 up
ADSL1 forced with DMT tool
Sync 4096 down 736 up Att 56dB forced S/N 10dB
Speed test 2252 down 646 up
ADSL2 forced with DMT tool
Sync 3854 down 695 up Att 55dB
Speed test 2312 down 570 up
UPDATE 1
NOW with forced ADSL1
Sync 4128/768
Speeds increased to 3168 down 651 Up
Notes: all are interleaved.
Router Netgear DG834N firmware V1.02.08
UPDATE 2 despite getting 4128 sync on ADSL 1 now, the BRAS profile appears to be clamping downloads to 2500 (2332 measured). Hopefully this will go back up to over 3000 again.
04-12-2008 12:46 PM
Router Information - ADSL:
Modulation: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 8,096
Output Power (Up/Down) [dBm]: 11.5 / 19.5
Line Attenuation (Up/Down) [dB]: 16.5 / 30.0
SN Margin (Up/Down) [dB]: 22.0 / 10.0
Router Information - ADSL2+: (uptime: 0 days, 0:02:27)
Modulation: G.992.5 annex A
Bandwidth (Up/Down) [kbps/kbps]: 1,000 / 12,211
Output Power (Up/Down) [dBm]: 12.5 / 22.5
Line Attenuation (Up/Down) [dB]: 17.0 / 33.0
SN Margin (Up/Down) [dB]: 8.0 / 6.0
I will carry out speedtests and post them later. It will be interesting to see how things settle down over the 7 day training period.
04-12-2008 1:57 PM
My download sync rate has increased from about 7648kbps to only 8517kbps
I think that my BRAS limiter is unchanged.
I am getting a lot of TCP re-transmits, which is causing a lot of sluggish browsing.
My router is not showing any difference in the way it connects - is this right?
04-12-2008 1:58 PM
04-12-2008 2:04 PM
I have a Netgear DG834GT - before rebooting I had no connectivity, I now have the connectivity previously described.
04-12-2008 2:15 PM
http://your.router.ip.address/setup.cgi?next_file=dsl_cfg.htm&todo=cfg_init
and select "ADSL2" under "DSL Mode", then apply and reboot router again.
B.
04-12-2008 2:34 PM
I only get a choice of
Quote * Multiplexing Method - Your ISP will indicate whether your Multiplexing Method is VC-BASED or LLC-BASED.
* Virtual Circuit - Your ISP will indicate which VPI/VCI combination is used for your service.
My firmware is V1.02.04
04-12-2008 2:38 PM
Whilst it may not achieve anything, it would be interesting to see if it makes any difference.
04-12-2008 2:40 PM
Edit - I enable debug mode so that may be the difference http://192.168.0.1/setup.cgi?todo=debug
04-12-2008 2:48 PM
Today 14:40 5240 kbps (655kB/s) 892 kbps (112kB/s)
Today 09:55 5913 kbps (739kB/s) 316 kbps (39.5kB/s)
Today 09:07 5766 kbps (721kB/s) 326 kbps (40.8kB/s)
Upload has increased but not download but it's been on only since 9:00.
