Speed Survey By The Gadget Show
- Speed Survey By The Gadget Show
- « Previous
- Next »
Re: Speed Survey By The Gadget Show
20-12-2007 9:29 AM
20-12-2007 10:12 AM
Our highest profile actually runs at 7150Kbps. Basically mirroring that of BT to ensure lower levels of packet loss.
20-12-2007 10:13 AM
It's all down to marketing your product in the most attractive way to get more customers regardless of the true picture.
I'm not saying that PN is conning people.
What I am saying is that's the state of this particular market and to stay up with the leaders PN's marketing has to match the competition.
Incidentally how would an 'honest' ISP publicize their broadband, at what speed exactly?
ISP "We have extensively tested your line and can offer you 5Mbps"
Customer "Thanks, I accept your offer"
6 weeks later
Customer "You said I would get 5Mbps and I'm only getting 3.5Mbps. You are in breach of contract"
There are so many variables associated with broadband speed how can any company offer anything fixed.
It has to be Up To until we are fibred and even then.......
Maybe we should tap into the Abilene Network
20-12-2007 10:43 AM
The reality is ADSL is going to be the way in which residential customers will get internet access for the next 6 to 8 years, maybe longer.
Any talk of FFTH, WIMAX or anything else becoming common place earlier than that would be disingenuous. 3G/4G/LTE may become available sooner but not likely to be the way the majority of people connect while at home.
While we are 'stuck' with ADSL, the ISPA and OFCOM need to work together to clarify this for the consumer.
SW.
3Mb FTTC
20-12-2007 11:33 AM
Unless every ISP has to show the likely speed a line could get, then there will be an every increasing confusion of one company can give me more than another, when in fact it is exactly the same thing.
Phil
20-12-2007 12:56 PM
And the discussion in this thread is focusing on ADSL sync speed, this does not matter a hoot when the exchange backhaul is congested and can only provide 1Mb on a line sync'd at 8Mb.
Is exchange a thing of the past?
Many savvy folks find it tricky to be clear about low sync speeds vs low data throughput caused by contention becase everybody says, 'go run a speedtest to find your line speed' ... uh NO!
SW.
3Mb FTTC
20-12-2007 12:59 PM
Following the comments in the article on ThinkBroadband, noone seems to be considering that this is still part of the problem.
20-12-2007 4:11 PM
Quote from: PJ
Sadly there's nothing either ISPs or users can do about exchange congestion.
Is that wholly true?
If there was enough discontent from consumers that the ISPA and OFCOM could encourage BTw to upgrade the backhaul from the exchanges to allow all lines on that exchange to operate at full speed 24/7 ... so on a 1000 line exchange with 500 people @ 3Mb, 400 people @ 6Mb and 100 people at 8Mb would require a meagre 4.7Gb of backhaul.
SW.
3Mb FTTC
20-12-2007 4:21 PM
Providing backhaul to an exchange essentially means providing a clear data path to one of those POPs from the exchange.
Backhaul is still expensive. Providing a 1:1 contention ratio on the backhaul would mean the wholesale price of broadband could increase by a factor of FIFTY.
If you want an uncontended service, you buy a leased line or SDSL and you pay for it.
Providing a 'meagre' 4.7GB of backhaul for one exchange would probably run into tens of thousands of pounds a month. This is why ADSL is sold as a contended service, and it is much more efficient and cost-effective having a backhaul that is 98% utilised than a backhaul that is 10% utilised but can burst to a full 100% if necessary.
B.
20-12-2007 4:36 PM
Indeed, the cost to the consumer would be very high much higher than today ... not sure the Gadgetshow folks would follow this thinking.
SW.
3Mb FTTC
20-12-2007 4:37 PM
I've seen 2.3, 2.7, 3 and 4 meg quoted as 'average' for the UK in the wall to wall surveys over the last few months. Few if any tell you how that figure was arrived at, although it's notable that an Ofcom statement a while ago bandied around one of the more optimistic numbers, suggesting it's more the side of the fence your wishful thinking sits on than reality that determines the quoted figure.
Quote from: Jameseh Exchange contention still plays a part in a number of speed issues.
Following the comments in the article on ThinkBroadband, no one seems to be considering that this is still part of the problem.
There's a world of truth in this. Since James kindly had my SNR reduced to 6db (tips hat to James), I've had a fair few resyncs (in the last week it's suddenly stabilised totally - still scratching my head on that), but generally better stable speeds, including a speedtest hitting a record 3,500 k, as opposed to the more normal 2,900 k. Thats 2,900 k if all is right and no-one else in East London is checking their email (3 am ish) because the actual daytime rate can be anywhere from 500 k to 2,500k, and the needle on the tester usually flaps about from one side to the other while testing. The 'good' version is so often 2903-2904 its almost scary, but the only emaningful figure is the average over a period of typical use, and that is definitely far, far less; 1800 average at a guess.
I'm sad enough to care about and (to a point) understand the variables that affect this, so (weekends excepted) I'm happy enough with what I get. But the average person buying what they believe is a 'mature' service is quite entitled to feel confused and aggrieved when the reality falls far, far short of the silky sales pitch - in which Plusnet indulge as much as anyone else.
So I'm very much in favour of any campaign that pressures Ofcom into doing their job properly and introducing a few metaphorical ISP knuckles to a stout doorframe or two. If the high profile campaigns and mainstream journalistic comments are poorly informed, that merely reflects the confusion sown by sales staff willing to deploy reality distortion fields in exchange for targets met.
20-12-2007 5:06 PM
We are talking about the Gadget show - perhaps to technology what the Sun is to informed and accurate political comment.
Quote from: Firejack I saw the Gadget this week and I have to say I thought the report on Broadband Speed was a particularly weak bit of reporting. Not sure if others will agree with me but it just seemed to focus on this one issue of "upto" instead of dealing with the bigger picture and why we face the problems we do.
Despite being intimately involved in the complexity of modern computer systems, I was actually quite impressed by the Gadget shows feature. The proposition appears very simple - that ADSL is being sold in an unfair and confusing manner. In my view, BT have been using the complexity of the technology to obfuscate this simple proposition and hiding behind wholesale to get away with it. 'Up To' is a very simple way for a largely ignorant customer base to see through the smoke and mirrors.
Quote -- Aging infrastructure
-- High Cost of Central Network Capacity
-- Poor technical understanding by customers
None of this would appear to be the fault of the customer though. The last point is a little debateable but when did you hear an ISP claiming connecting to the internet was anything other than simple? Claiming it is simple in the sales literature and then claiming it is not having taken the money is misleading. Very few other industries can get away with such behaviour.
Quote Since around 12 months ago I've strongly believed we need a Fibre-To-The-Home solution.
Fibre to the street maybe. More to the point, who is going to pay for it, fibre is relatively expensive. It may be a better long term solution but since IT became a consumer product time and again consumers prove they only differentiate products they do not understand on bottom line cost. It does not matter how technically superior a product is, or how much better the service may be. Nowhere is this more apparent than the ISP marketplace where companies like Plus are expected to operate on ridiculously tight margins.
Quote Many experts in the business world are against it because they see no need for 100Mbps connection and I tend to agree for the time being. But the point of getting a FTTH solution is the technology is designed for the Internet and hasn't had to be adapted like ADSL has ADSL suffers from all sorts of complicated technical issues like line length and attenuation which people don't understand or bother to even learn about and is probably the reason the general public is jumping onto this "upto" band wagon.
FTTH offers a release from all these confusing technical terms and would allow companies to sell with confidence 100Mbps to a customer for example and know that is exactly the speed they would receive between themselves and the exchange.
I would be interested to here how exactly you propose to supply this 100Mbps service? Fibre only describes the barer which is only one component in the physical layer. There are several more components which need to be assembled and two additional logical layers to negotiate before you can assign an IP address.
ADSL is merely the current incarnation of what started out as the 150bps acoustic coupler. It is complicated and fragile for the same fundamental reasons an F1 car engine is complicated and fragile. Unlike an F1 car ADSL just happens to be very cheap to provision.
You can have a 100Mbps fully syncronous connection supplied to your door today. It will be highly reliable because it does not involve pushing the underlying technology to the limits of feasibility - but it will cost a great deal of money to provision.
There is not a networking technology in existance which does not have it's own set of complicated technical issues. The mistake to my mind is not that these issues exist but that customers have been fooled into thinking they do not exist and are left holding the baby when they prove to be an issue.
Up To 8Mbps can be regarded as a claim to provide something for nothing - a scam by any other name.
Originally BTW supplied ADSL based on the connection speed obtainable by the customer and selected by the customer. This was a clear and simple way of selling the service. It turned out few people were willing to pay the premium for higher bandwidths - which in reality cost little more to provision. Such customer choice did not suit BTW.
The current pricing model is far more favourable to BTW particularly considering the ignorance of the customer base. Everyone gets provided the maximum possible bandwidth and gets charged for the data transferred over it. This is closer to the model used by transit providers and data-centres but in those scenarios the costs are high enough to justify investment in traffic management.
ISPs like Plus.net have had to bare the complaints resulting from fair usage policies which became essential after BTW changed the pricing model. They have to suffer the burden of trying to educate customers to the complexity of the technology which the customer simply is not interested in (why should they be). They have to invest in traffic management because their customers do not know how to do it. They have to do all these things working on a stupidly low margin above the cost BTW charges to every ISP. What you might take from this is that ISPs that manage to turn a profit are incredibly more efficient than the supplier they have to rely on.
Quote The other real issue I've had with the Gadget Show is their attitude of everyone should complain even if they don't know what they are complaining about. It would of been much more helpful if they went out and talked to the experts and put together a useful presentation about where the problems are and then research what each ISP is going to resolve these issues.
I do not see how ISPs can resolve it without investing in their own local loops.
Quote Several times they also have mentioned complaining to OFCOM. Now if they had done any research they would understand OFCOM is a bigger part of the problem then BTwholesale.
OFCOM has the power to enforce change, simple as that. Whether the complaints are wholly correct is not so important. A suitable level of complaint will force OFCOM to take action to stop them however they are expressed.
Quote OFCOM has mismanged the telecoms industry for years. They have forced BTw into opening its network to its competitors. They have forced BTw to keep artificially high wholesale prices on bandwidth to keep prices high and move customers onto competitors of BTw such as Cable from Virgin Media. Then they have also set stupid restrictions on BTw like forcing them to maintain the physical connections of users on rival networks. To me this seems completely insane and almost like the government has forgot they sold off BT to the private sector years ago. I'm all for anti-monopoly rules but not interfering this much.
BT had a massive advantage when it was sold off. Not quite a 100% share of the market (thanks to Hull telecomm) but just about. Many of those measures imposed by OFCOM only gave BTs competitors a fighting chance against a company which has a history of displaying anti-competitive behaviour. Remember that consumers paid for BTs network and infrastructure over 40 years of paying taxes. It is only right that consumers are given a chance to benefit from competition. Whether such has happened is far more difficult to guage as all the major telecomms providers seem to have made massive mistakes in the UK. Conjecture might lead one to speculate those mistakes were the result of being too greedy and too aggressive in the pursuit of short term profits.
OFCOM are regulators they are not strategy planners. The telcos are responsible for deciding their own strategies. OFCOM simply prod them to ensure they play fair. Unfortunately the change to reactive development comes along with the profit driven competitive markets. All the infrastructure companies seem to have gone the same way. Minimal investment, maximum profit.
Quote Maybe it wouldn't be so hard to like OFCOM if they had any sort of plan for the development of telecoms in the UK but they plainly don't have a clue.
Quote What I'd really like to see next year is all the people that matter and are the true experts get together and thrash out a solution and then see some sort of live discussion on say BBC Newsnight to explain whats being going wrong and what is going to be done to fix it before the Internet melts down in this country after overloading.
What I would like to see is the politicians doing what they are paid to do. At the moment there seems to be a lot of head scratching and shrugging of shoulders - We don't understand therefore we will do nothing. There are a number of major technology corporations getting away with practises that would not be tollerated in virtually any other market sector. We all know that the UK is seen as fair game for inflating prices. These corporations are not going to stop voluntarily. Personally I would be quite happy for them to be informed by way of legislation that they must treat UK consumers fairly or risk losing the business of 60,000,000 relatively well heeled and very polite customers.
So a thumbs up from me to the Gadget show for making a complicated issue very simple. From the length of my post you might have worked out it is something I personally struggle to achieve.
20-12-2007 5:23 PM
Nice post and I think it summarises everything fairly succinctly
B.
- « Previous
- Next »
