Speed Speed Speed!!!!!
- Speed Speed Speed!!!!!
08-02-2009 4:09 PM
My download on tester is at 30k/s and yet my upload is at 46k/s... I have had it getting lots more than this in the past.
I play games a lot and my enemy is lag. I have been with plusnet for over a year now and it keeps getting slower by the day. I'm gonna go this month (Febuary), and if no improvement is made I'm off to get another provider.
I know all the long cable stuff and heard it all before, but I know I can get well over 100k/s download speed coz I have had it. I used to be able to watch movies without hassle, now I have to wait for an hour before I start to watch it.
I'm not interested in the technical stuff... I want my speed back that I know I can get and not a trickle of data that you allow.
I'm not even getting a 128k line let alone the UPTO 8MB that Im paying for.
Re: Speed Speed Speed!!!!!
08-02-2009 4:14 PM
You keep referring to k's - are you using kb/sec or kB/sec throughout or are some different as the numbers are confusing me
Also which tester are you referring to
08-02-2009 4:16 PM
08-02-2009 4:23 PM
08-02-2009 4:26 PM
What is your current sync rate from your router
What does this say your current line speed is https://portal.plus.net/my.html?action=data_transfer_speed
What does the BT speedtester give http://speedtester.bt.com/
Have you exceeded your usage allowance
08-02-2009 4:28 PM
After a reboot of router
08-02-2009 4:31 PM
Estimated line speed:
Not recorded (service activated before we introduced estimates).
Current line speed:
250 <<<<<<<<<<<< this was at 1000 last time i looked
What is going on... I'm not happy in the slightest
08-02-2009 4:37 PM
Due to a low sync your IP rate has dropped to 250kbps
The numbers you give after reboot of the router - is that from a speed test or from the router stats.
Please advise full router stats - speeds, attenuation and noise margin
08-02-2009 4:41 PM
I feel like I have a Ferrari with a Fiesta engine in it....... I have no idea what you tech bits are or how to find them all.
I just want my speed back, I've had no problems with connections or anything so why would it slow down. Who slows it down and who can speed it back up again.
I'm trying hard not to swear here but I'm VERY ANGRY at the moment.
08-02-2009 4:46 PM
It looks at the moment that there is a problem with your line (nothing to do with Plusnet) and unless you give the information requested we won't be able to help.
If you can advise the model of router you have we will be able to tell you how to get the information from it.
08-02-2009 4:49 PM
My router is a BT voyager 2110
Its just so hard to do anything with useless speed.
08-02-2009 4:54 PM
Quote From the web interface http://192.168.1.1
Click Advanced...|Status in the centre of the page
This opens up a new menu on the left hand side of the page.
Under Status
> Broadband Line
"More Information" gives you line error information stats
Default login: "Admin". Password: "Admin" or "Password"
08-02-2009 4:58 PM
The folks round here are really helpful but they do need a little info to go on, hang in there.
08-02-2009 4:59 PM
Line Mode G.DMT Line State Show Time
Latency Type Interleave Line Up Time 00:00:31:26
Line Coding Trellis On Line Up Count 1
Statistics Downstream Upstream
Line Rate 1792 Kbps 448 Kbps
Noise Margin 9.1 dB 16.0 dB
Line Attenuation 63.0 dB 30.5 dB
Output Power 16.8 dBm 12.1 dBm
K (number of bytes in DMT frame) 57 15
R (number of check bytes in RS code word) 16 4
S (RS code word size in DMT frame) 4 4
D (interleaver depth) 8 8
Super Frames 110976 110974
Super Frame Errors 26 0
RS Words 1886608 1886558
RS Correctable Errors 1483 0
RS Uncorrectable Errors 142 0
HEC Errors 23 0
OCD Errors 0 0
LCD Errors 0 0
ES Errors 0 0
08-02-2009 5:07 PM
That tells me that you should indeed be getting better speeds.
However - and this is going to be a bit technical.
The way the automatic system works at the exchange is that it limits the speed at which you can download to a figure a bit under your sync rate. The bad bit is that a drop in sync rate for whatever reason triggers a drop in this speed limit and because of the way the stupid system works it then won't increase it again until the line has been running at that higher speed for three days.
In your case there would have been a quite remarkable drop in sync rate - possible reasons include plugging in an unfiltered device.
As a final check can you try to run the BT Speedtester http://speedtester.bt.com/ which will among other things advise the IPrate (this is the rate which the automated system is limiting you to. (It may take a few tries)
If this is different to the Plusnet figure you gave earlier then we can address that. If, and I suspect it will be, it is the same the only recourse is to wait until the system increases the rate
This tells you how to run the test http://www.plus.net/support/broadband/troubleshooting/bt_speed_tester.shtml
