Speed Saturday night
- Re: Speed Saturday night
18-12-2016 1:25 AM
My usual speed is around 4.76 mbps. Saturday night and into Sunday morning am getting around 1.6 mbps. Please put my speed back up.
18-12-2016 5:51 AM
Try disconnecting your internet via your router if you know how too, wait 30 seconds then connect again and see if that helps. Sometimes it helps if you are using a congested gateway.
18-12-2016 9:48 AM
Hello @brendajorsler
Sorry to hear you are experiencing slow speeds. I've been testing your broadband:
Upstream DSL Link Information | Downstream DSL Link Information | |
Loop Loss: | 29.3 | 49.5 |
SNR Margin: | 5.9 | 11.0 |
Errored Seconds: | 0 | 2 |
HEC Errors: | 0 | |
Cell Count: | 123 | 1945 |
Speed: | 1147 | 4544 |
I'm not finding an issue with your speed. Are you still having problems?
18-12-2016 12:49 PM
You're not finding an issue? What about the high downstream SNRM, and possibly banded downstream speed?
18-12-2016 12:57 PM - edited 18-12-2016 12:58 PM
I was in a similar position and for days I thought it was either the router at fault or PN.
A simple change of the channel and everything is going great so far. Download an app. that tells you who's on what (channel) nearby and change accordingly.
18-12-2016 1:34 PM
Apologies for that.
Profile Info: |
WBC 2M - 4M No delay (INP 0) 6dB Downstream, UC No delay (INP 0) 6dB Upstream (ADSL2+) |
It is banded. I've reset the line and removed the banding. I'm going to be monitoring the connection to see whether it remains stable.
18-12-2016 4:30 PM
I didn't do anything to try to rectify the slow speed on Saturday night and yet Sunday morning it was back to normal (4.6mbps)
18-12-2016 4:39 PM
I'm not being able to identify the cause of that. Hopefully it doesn't happen again.
