Speed Profile
- Re: Speed Profile
Speed Profile
08-04-2014 6:50 PM
Hi all,
Could someone please have a look at my speed profile as I think I am currently stuck on a lower one? I get 67 Mbps on average.
Thank you very much.
Message 1 of 6
(828 Views)
5 REPLIES 5
Re: Speed Profile
09-04-2014 10:18 AM
Hi Mastermind78,
I've given your connection profile a nudge to match your sync speed.
Hope this helps!
Hope this helps!
Message 2 of 6
(508 Views)
Re: Speed Profile
09-04-2014 8:36 PM
Hi Linn,
Thank you very much, that helped a little bit! I am currently getting 69.30 Mbps on average with a current line speed of 73.6 Mbps. Out of curiosity, is this the absolute maximum performance my line can reach?
Message 3 of 6
(508 Views)
Re: Speed Profile
10-04-2014 10:59 AM
Hi Mastermind78,
The speeds that you're getting now are probably the maximum they will be on an 80/20 circuit
Message 4 of 6
(508 Views)
Re: Speed Profile
15-04-2014 7:03 PM
Hi Chris,
I have actually run few speed tests last night getting an average speed of 73.30 Mbps with a current line speed of 77.80 Mbps. My line speed has improved further, which is great and I can't complain now...However, is there a particular reason why my current line speed keeps changing? It's slightly lower tonight. (77.40 Mbps)
Thanks.
Thanks.
Message 5 of 6
(508 Views)
Re: Speed Profile
16-04-2014 10:48 AM
Your Speed Profile will automatically adjust depending on a report that we get from our suppliers. If the report shows that your line speeds have improved, then we will update our Speed Profile so that you get the best possible speeds
Message 6 of 6
(508 Views)
