Speed Problems
- Speed Problems
Speed Problems
15-12-2008 5:09 PM
Its the least they could do with the shocking service. When I first started with f9 I had 3-3.5Mb now i get 1-1.5Mb (same hardware).
Very dissapointed to say the least.
Re: iplate
15-12-2008 5:15 PM
Have you posted about your poor speeds before? I'm fairly certain that I haven't seen anything from you before and to say that it's simply a shocking service is a touch on the vague side
Have you tried connecting directly into the test socket on your master socket? Have you tried replacing your filter and [possibly trying to use a different modem or router to see if the connection speeds remain the same?
I've just run a check on your connection and it looks like there's a bit of noise on your line, giving some connection errors and a slightly higher than usual noise margin. Could you please try some of the things I suggested above and we'll see where we can go from there.
By the way, and I'm sorry if I'm telling you how to suck eggs - we have absolutely no control over your synchronisation speed. that's entirely down to the connection from your router to the BT exchange.
link:speed
Re: iplate
15-12-2008 5:17 PM
Re: iplate
15-12-2008 5:26 PM
Have a read of these articles.
http://www.jarviser.co.uk/jarviser/broadbandspeed.html
http://www.dougrice.plus.com/Erlangs/adsl.htm
Disconnecting the bellwire solved my speed/connection/stabilty issues.
Re: iplate
15-12-2008 6:04 PM
Quote I'm fairly certain that I haven't seen anything from you before
Previous post June 2007
Re: iplate
15-12-2008 6:21 PM
Thanks if you can answer this.
Re: iplate
15-12-2008 6:36 PM
Re: iplate
15-12-2008 6:47 PM
What is the status of your exchange? http://usertools.plus.net/exchanges/
Re: iplate
15-12-2008 6:54 PM
Quote from: adiewoo Is it just the throughput that you are seeing reduced or your synch speed?
synch speed has reduced since plusnet took over. I used to get 5-6Mbs even when my router was connected to a extension 20m FROM ms
Checked exchange status. currently RED. The ETA fix time is: 11 Jan 09
Red 01 Dec 08
Red 24 Nov 08
Green 17 Nov 08
Green 10 Nov 08
Red 03 Nov 08
I guess its F$%^ing BT again
Re: iplate
15-12-2008 7:14 PM
Can you provide the stats we have been asking for.
Re: iplate
15-12-2008 7:42 PM
Quote from: Oldjim The exchange being red has nothing to do with your synch speed.
Synch speed has dropped. I know actual d/l / uplad speeds will be less than synch speeds. I just cant understand the massive drop in synch speeds reslting in poor d/l speeds. I want to try the iplate see if that helps my snr. Removing the bellwire might not be eonough ( IIRC there is additional filtering in the iplate) ?
Re: iplate
15-12-2008 8:00 PM
If you connect the router to the test socket this removes your internal wiring and also the ring wire from the connection.
Once you do this we need to know the attenuation, noise margin and synch speeds both up and down. With this information it is possible that the reason for your low speeds will show itself.
Re: iplate
15-12-2008 10:34 PM
Sorry to hear that you're having problems. Clearly from what we know already some kind of fault exists. Before we even get close to looking at an iplate we need to learn a bit more about your problem. The iplate is not the be all and end all of adsl fault resolution.
There are many helpful and kowledgeable people in the forum community who will help you get to the bottom of this quickly. If thats not the way you wish to go then raise a fault report to our support team and we'll take it from there. Or you could always do both. Either way we'll get this identified and fixed.
P.S we didnt take F9 over. We'vd always owned it.
Re: iplate
15-12-2008 11:17 PM
What you need is a high speed modem cable which you can get from currys or any other good shop this has a multi insulated twisted pair and gold connections with a super braid on the outside and connects from the socket to your router. This is the cable often forgotten and is normally very poor quality and picks up noise and reduces speed because this is what the router sees as the line. I have just got one and its made a difference straight away reducing noise and everything
Re: iplate
16-12-2008 9:54 AM
