Speed Problems
Ravinella
Speed Problems
Currently having problems with the download speed of my ADSL.
Stats from the Draytek 2862 router are
Profile according to Plusnet
BTW Test check results
Anyone available to have a look as there's something not adding up here and my speed is crippled
2 REPLIES 2
MatthewWheeler
Fixes: 437
Re: Speed Problems
Thanks for getting in touch @Ravinella
I'm sorry to hear that you're having issues with your connection.
I've tested your line and it appears it's dropping quite often and our tests have also highlighted a fault on the phone line known as an 'Earth Contact'
Unfortunately as we aren't your phone provider we can't report this for you so I'd recommend contacting your phone provider so that they can get that resolved for you
 Matthew Wheeler
Ravinella
Re: Speed Problems
Thanks for the pointer, I'll get in touch with my phone provider
