Speed Outside Estimated Range
- Speed Outside Estimated Range
- « Previous
- Next »
Re: Router Data rate vs. Max rate
06-05-2019 10:01 PM
@jthom wrote:
Connected to the master socket. Test socket increases speed by about 5-10mbps on both max and data rates, but the speed test is the same.
This suggests you don't have a filtered mastersocket, and your internal wiring is reducing the data rate that you could get.
The first thing an Openreach engineer would do if called out for a fault would be to replace the Master Socket, and then you speeds should be a lot better.
Re: Speed Outside Estimated Range
07-05-2019 8:04 AM
@jthom, your minimum guaranteed access line speed is 49.4mbps. It's based on the lowest value of your estimates as shown at http://www.dslchecker.bt.com. Your sync rate of 49.8mbps is just above this but definitely below where we'd expect, so I'd recommend raising a new fault ticket at http://faults.plus.net so we can arrange an engineer to get this investigated.
- « Previous
- Next »
