Speed Ok ish but everything has slowed down
Legend
Fixes: 293
Re: Speed Ok ish but everything has slowed down
@destiny234 Could you post those two pages from your router again, please, would be interesting.
destiny234
forgot to say Brian, I checked open reach and standard is 24 Mbps and Superfast fibre 10-18 Mbps
seems the wrong way round ?
Linda
destiny234
destiny234
for John 🙂
Legend
Fixes: 293
Are those new screenshots, Linda? If so, the problem is not resolved.
destiny234
Sorry John, I think you mean the new ones, hang on .....
destiny234
Legend
Fixes: 293
Still not corrected, looking at that, Linda,  Can you post a result from this speed test site, please https://www.speedtest.net/ .
Mustrum
Fixes: 79
What has caught your eye John?
The speeds are reported the wrong way round, but the upload data seems hight.
destiny234
speed test after.jfif
Legend
Fixes: 293
Yes, the speeds are reported 'back to front', and the upload is wrong for your attenuation, but the thing that makes me wonder if things are corrected is your downstream SNR figure of 3.2 -that is much too low for a line of your length - it should read 6.0 or slightly higher.
The speed test would confirm if what they claim to have done has had any effect.
See my later reply.
Legend
Fixes: 293
Well, your download is much better, but I'm still suspicious of the SNR . Your upload speed is probably about right for your line though. - I forgot it can in theory reach 10Mb/s on FTTC.
destiny234
John, he did say it might take a couple of days, and to get in touch again if it wasn`t right. I will let you know how it goes. It`s great to find people so keen on this stuff and helping others. Sorry I have been so thick 😉
Linda
destiny234
forgot to say, the last bt that was out said to try `unplugging` the phone line from the back of the router?
I haven`t tried that yet, what do you think?
Linda
Legend
Fixes: 293
OK. I'm away in Devon for 4 or 5 days from tomorrow, so probably won't be around until after the evening meal, but I'll keep my eyes peeled, The problem with such a low SNR is that if there are any errors, there is no 'wriggle-room' and you could see your speeds plummet again as the Dynamic Line Management (DLM) tries to correct for them.
