Speed Not As Estimated
flamazine
had my fibre connection up for about 6 hours now and the download speed wont go any faster than  34 Mbps upload speed is around 13mbps . checked a few times and its not the speed i was estimated at when i signed up. Estimated download speed: 62 Mbps  Estimated upload speed: 20 Mbps . How long  a wait  is it until i get the speed im paying for?
cheers
adie:red removed all caps title as per link:rules
Strike
Re: new user
I'v got new a connection up a few hours and I had a similar problem you had.. If you ring Customer Service - they will correct the speed profile for you and it will be done by tomorrow.
dick:quote
flamazine
Re: new user
cheers
flamazine
Re: new user
didn't ring customer service. opened a ticket on help assistant . still waiting for a reply Sad
flamazine
Re: new user
Just tested again and now only getting 12mbps . i was getting better speed from Sky adsl . im beginning to think iv'e made a mistake by moving to plusnet..
flamazine
Re: SPEED NOT AS ESTIMATED
Still slow speeds . Help!
Re: Speed Not As Estimated
Hi flamazine,
Sorry for the delay in replying.
Are you connecting wired or wireless to your router? I've had a look at your connection and account and you should be seeing speeds in the high 70Mb/s, can you try a <a href="http://community.plus.net/library/broadband/fibre-help-how-to-set-up-a-pppoe-dialler-in-vistawindows-7/>PPPoE</a> connection and see if there's any difference?
flamazine
I have connected using both wireless and Ethernet . When ionwireless i get 15-20 Mbps. On ethernet 70Mbps  so i must have a problem with my wireless or is this about normal for wireless connection.
cheers
I'd suggest tweaking your wireless settings. You can do this at <a href="http://www.plus.net/support/broadband/wireless_broadband/wireless_signal.shtml">here</a>. This should help.
