Speed Loss
G3YBO
Speed Loss
Just noticed my speed has dropped.    No work near my cabinet....  Have made a report to Plusnet on main site..  My up speed is now faster than down speed.....
Have reset router and BT modem......Any help please........Roger
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: Speed Loss
Hi G3YBO,
To help us with our investigation, can you please visit http://speedtest.btwholesale.com and complete the initial speed test and then also click 'Further Diagnostics' and run the second speed test?
The results are stored and uploaded so that we can see them and we can use the results to help us work with our suppliers to resolve the issue for you.
Chris Pettitt
Cloud Environments Engineer
G3YBO
Re: Speed Loss
Ok Chris..............Yes done that and had a reply from them.....
Thanks for a quick reply......
Regards
Roger
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: Speed Loss
Thanks Roger,
Our Faults Team will pick this up as soon as they can and they'll be in touch Smiley
Chris Pettitt
