Speed/Line Issue - what to do next?
- Speed/Line Issue - what to do next?
Re: Speed/Line Issue - what to do next?
21-05-2014 6:44 PM
xDSL
xDSL
Mode ADSL_2plus
Traffic Type ATM
Status Up
Link Power State L0
Downstream Upstream
Line Coding (Trellis) On On
SNR Margin (dB) 7.3 20.2
Attenuation (dB) 47.5 26.5
Output Power (dBm) 0.0 12.3
Attainable Rate (Kbps) 7932 840
Rate (Kbps) 3069 440
MSGc (# of bytes in overhead channel message) 94 12
B (# of bytes in Mux Data Frame) 6 55
M (# of Mux Data Frames in FEC Data Frame) 1 1
T (Mux Data Frames over sync bytes) 9 1
R (# of check bytes in FEC Data Frame) 8 8
S (ratio of FEC over PMD Data Frame length) 0.0718 4.0000
L (# of bits in PMD Data Frame) 1671 128
D (interleaver depth) 416 8
Delay (msec) 7 8
INP (DMT symbol) 7.50 2.00
Super Frames 23240065 20620387
Super Frame Errors 25118 3
RS Words 908620287 3428109
RS Correctable Errors 10482 29
RS Uncorrectable Errors 53 0
HEC Errors 298578 0
OCD Errors 0 0
LCD Errors 0 0
Total Cells 118101751 16903301
Data Cells 15243598 1362381
Bit Errors 0 284
Total ES 4154 3
Total SES 342 0
Total UAS 259 259
Edit: Restarted connection after this post and now have lots of packet loss, high ping times when packets do go through etc.
-Ash
22-05-2014 9:54 AM
22-05-2014 12:32 PM
-Ash
22-05-2014 12:47 PM
Looks like your modem resynch'd as well. This happening after a line test rather points to a bad joint somewhere.
22-05-2014 12:55 PM
[table][tr][td]
22-05-2014 1:04 PM
Are you on a fixed IP address?
22-05-2014 1:11 PM
-Ash
30-05-2014 11:21 PM
-Ash
02-06-2014 3:36 PM
08-06-2014 10:23 PM
Has been particularly all day today, random disconnects from games etc. voice apps breaking up, during times of disconnects no net activity (everything typical of the original fault) is there anything different i can expect this time? or will it be like a typical first visit. where engineer comes tells me line runs perfectly and leaves with my line still having an issue? should i pull up both tickets for him to read or should he have all the info from recent visits previously?
-Ash
08-06-2014 11:14 PM
Sorry to see that your issue is dragging on.
I would have a look through your RouterStats graphs and look for marked shifts in SNRM, especially if there are repeated similar shapes or times or time intervals. The more you can put in front of the engineer the better - do not forget about other users having issues in the area.
Get some hob nobs and try to get them to have some with a hot brew! Hopefully you'll get an SFI engineer.
Kevin
09-06-2014 9:44 AM
We've got the previous ticket details on our systems, so don't worry about that. I've just updated your Fault Ticket and booked an engineer in for you.
09-06-2014 5:50 PM
Pinging portal.plus.net [212.159.9.2] with 32 bytes of data:
Reply from 212.159.9.2: bytes=32 time=1917ms TTL=249
Reply from 212.159.9.2: bytes=32 time=3625ms TTL=249
Reply from 212.159.9.2: bytes=32 time=3396ms TTL=249
Reply from 212.159.9.2: bytes=32 time=1290ms TTL=249
Reply from 212.159.9.2: bytes=32 time=2483ms TTL=249
Reply from 212.159.9.2: bytes=32 time=2064ms TTL=249
Reply from 212.159.9.2: bytes=32 time=201ms TTL=249
Reply from 212.159.9.2: bytes=32 time=2154ms TTL=249
Reply from 212.159.9.2: bytes=32 time=106ms TTL=249
Reply from 212.159.9.2: bytes=32 time=2327ms TTL=249
Reply from 212.159.9.2: bytes=32 time=134ms TTL=249
Reply from 212.159.9.2: bytes=32 time=2340ms TTL=249
Reply from 212.159.9.2: bytes=32 time=541ms TTL=249
Reply from 212.159.9.2: bytes=32 time=3132ms TTL=249
Request timed out.
Reply from 212.159.9.2: bytes=32 time=1330ms TTL=249
Reply from 212.159.9.2: bytes=32 time=3531ms TTL=249
Reply from 212.159.9.2: bytes=32 time=2861ms TTL=249
Reply from 212.159.9.2: bytes=32 time=3829ms TTL=249
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 212.159.9.2: bytes=32 time=607ms TTL=249
Reply from 212.159.9.2: bytes=32 time=68ms TTL=249
Reply from 212.159.9.2: bytes=32 time=46ms TTL=249
Reply from 212.159.9.2: bytes=32 time=47ms TTL=249
Ping statistics for 212.159.9.2:
Packets: Sent = 27, Received = 22, Lost = 5 (18% loss),
Approximate round trip times in milli-seconds:
Minimum = 46ms, Maximum = 3829ms, Average = 1728ms
however when checking plots on dnrm etc nothing obvious shows and errors not increasing at the time this happens.
Ash
10-06-2014 11:08 AM
Ash
10-06-2014 7:02 PM
-Ash
