Speed/Line Issue - what to do next?
- Speed/Line Issue - what to do next?
Re: Speed/Line Issue - what to do next?
17-05-2014 10:21 AM
Will be in work most of the day today so wont be able to post anymore graphs till later if required.
-Ash
17-05-2014 10:47 AM
A fall of 2dB or so is to be expected during the night due to MW radio interference.
The early hours blip - without looking at the router log, it is difficult to be confident about what happened here. Zero synch has been recorded, but not zero SNRM as would be expected from a resynch event. I'd suggest a missed data sample.
Now the logging is in place, let's see what it reveals over the weekend.
17-05-2014 8:16 PM
May 17 19:34:23 daemon err syslog: dhcpd:sending ACK to 192.168.0.6
May 17 20:00:21 daemon notice syslog: pppd:LCP terminated by peer
May 17 20:00:21 daemon crit syslog: Clear IP addresses. PPP connection DOWN.
May 17 20:00:21 daemon crit syslog: Clear IP addresses. Connection DOWN.
May 17 20:00:24 daemon notice syslog: pppd:Connection terminated.
May 17 20:00:24 daemon notice syslog: pppd:Connect time 587.6 minutes.
May 17 20:00:24 daemon notice syslog: pppd:Sent 633536054 bytes, received 984986039 bytes.
May 17 20:00:27 daemon notice syslog: PPP: Start to connect ...
I've changed my graph to sample more frequently, any suggestions on length of time for samples?
Edit: Sync speed remains the same
-Ash
17-05-2014 8:52 PM
Personally I sample at 10 second intervals, with 720 points per plot, which gives a graph spanning 2 hours.
Right click on the graph and select "scheduled capture" this is save the graph every two hours so you can take a look back at what has been happening.
17-05-2014 9:30 PM
symptoms in game are micro freezes and speed ups etc. same as normal haven't forced a manual disconnect and just about to install wireshark on this PC
-Ash
17-05-2014 9:30 PM
-Ash
17-05-2014 9:41 PM
Quote from: dragona on unlimited package so shouldn't have an issue with capping.
Ash,
There are different kinds of capping!
I do not think WireShark is going to add any benefit here. The BT results an issue, I'll try to take a closer look later - SWMBO has returned from work, so I'm off out for a beer!
Kevin
19-05-2014 10:49 AM
Your sync speeds does appear to very quite widely though. I can't see any congestion issues at your Local Exchange.
Do you notice poor speeds at any time in particular?
19-05-2014 11:12 AM
-Ash
19-05-2014 11:13 AM
Do you have a TBB Monitor?
19-05-2014 11:39 AM
19-05-2014 11:49 AM
You need to modify the img tag in your sig before one of the mods feels your collar, as there is a 100 pixel limit on sig heights.
[img width=170 height=75]
Kevin
19-05-2014 5:33 PM
-Ash
20-05-2014 4:41 PM
It looks like there is some traffic being passed through (other than browsing), anything you can think of?
20-05-2014 5:32 PM
-Ash
