Speed Issues
- Speed Issues
Speed Issues
24-03-2011 9:46 AM
Account username: scratchrat
When you signed up for your broadband account, we performed a check on your telephone line to give you an estimated speed your line might achieve.
Now that your service has now been active for 14 days, we thought we'd let you know the speed as it stands today, by way of comparison.
Estimated line speed: 4Mbps
Current line speed: 1.25Mbps
Is this normal? My speed had been this low since the start and I hoped it would improve after the 10 day settling period.
Re: Speed Issues
24-03-2011 10:39 AM
I'll take a look at this now for you and see what I can find out.
Jojo
Re: Speed Issues
24-03-2011 10:59 AM
I've just ran some checks and the line has been banded so this sets the maximum sync rate your connection can achieve. This is something we can work on but the first thing we need to do is work out why your connection keeps dropping (as you can see below) Have a look here regarding troubleshooting a dropping connection - particularly the part about the test socket and let me know if you find anything that may have caused it or if you have plugged into the test socket. I'm quite confident that we can get the speed estimate though.
Jojo
Re: Speed Issues
24-03-2011 12:29 PM
My problem is that my speed has been stuch at 0.9Mb since the 2nd of March, with the exception of 3days in the middle when i got a solid 6.5-7Mb. Since the line went active, i've been syching at 8128 and havent changed anything since i moved. My current stats (as of this morning) are below:
DSL Status: Connected
DSL Modulation Mode: MultiMode
DSL Path Mode: Interleaved
Downstream Rate: 8128 kbps
Upstream Rate: 448 kbps
Downstream Margin: 11 db
Upstream Margin: 27 db
Downstream Line Attenuation: 15 db
Upstream Line Attenuation: 3.5 db
Downstream Transmit Power: 12 db
Upstream Transmit Power: 19 db
________________________________________
PVC Connection
Encapsulation: RFC 2364 PPPoA
Multiplexing: VC
Qos: UBR
Pcr Rate: 0
Scr Rate: 0
Autodetect: Disable
VPI: 0
VCI: 38
Enable: Yes
PVC Status: Up
And before the BT speed tester stopped working, it reported that my IP profile had gone up to 7150 (which i think is the maximum). The my broadband speed site has kindly recorded the following:
Date Download Speed Upload Speed
Today 06:46 916 kbps (115kB/s) 377 kbps (47.1kB/s) Share
Yesterday 20:20 916 kbps (115kB/s) 380 kbps (47.5kB/s) Share
Mar 10, 08:17 926 kbps (116kB/s) 354 kbps (44.3kB/s) Share
Mar 10, 08:16 929 kbps (116kB/s) 355 kbps (44.4kB/s) Share
Mar 7, 17:41 920 kbps (115kB/s) 380 kbps (47.5kB/s) Share
(sorry for the formatting!)
I've raised a couple of tickets (#40777536 was one) but have got the standard "Speed will fluctuate" response, but it's not really fluctuating - it's either 0.9mb or 6.5Mb-7Mb, for those few days in the middle. I have eliminated any possbile issues with microfilters etc without change, and tried the test socket behind the master plate. The only thing i cant test is another router (as i only have one) but since it managed 6.5-7Mb for those few days i think it's ok.
My profile on your site is a little off as well:
Postcode:
Phone exchange:
ALLOA
1.0Mb (This may vary between 1Mb and 3.5Mb) - Checked on 2011-02-01 11:05:03
Current line speed:
1 Mb
This is my old pre-move exchange and line speed, i dont know if that would be causing this though.
I'd appreciate if you could look into this for me
Thanks,
Alan
Re: Speed Issues
24-03-2011 12:51 PM
Plusnet reps here on the forums can get it updated for you - just wait until one of them picks it up.
Re: Speed Issues
24-03-2011 12:59 PM
Cheers,
Alan
Re: Speed Issues
24-03-2011 2:55 PM
I've sorted that for you now, you should see the correct speed within the next 15 minutes.
Jojo
Re: Speed Issues
24-03-2011 3:01 PM
great stuff!
Thanks very much,
Alan
Re: Speed Issues
25-03-2011 8:28 PM
Re: Speed Issues
25-03-2011 9:14 PM
If you can keep the connection stable with no drops in connection I can get the banding lifted.
Jojo
