Speed Issues
- Speed Issues
Speed Issues
21-11-2013 6:33 PM
So I have finished my house move and done some speed tests etc and found my once decent speed of 4.5-5mb when I moved in 4 months ago which was stable until a couple of weeks ago is now significantly lower, here is the detail:
From Plusnet link
Estimated line speed:
Current line speed:
7.15 Mb
From BT Wholesale test
BT Wholesale Broadband Performance Test
Broadband Speed Test Results
Download speed (Mbps) 1.94
Upload speed (Mbps) 0.38
Ping Latency (ms) 42.00
Router Information
ADSL Status
Parameters
DSP Firmware Version A2pB025f.d22k
DMT Status No Defect
Operational Mode G.DMT
Upstream 448
Downstream 2496
SNR Margin(Upstream) 21.0
SNR Margin(Downstream) 15.9
Line Attenuation(Upstream) 21.5
Line Attenuation(Downstream) 47.0
Any help would be much appreciated.
Re: Speed Issues
21-11-2013 6:37 PM
Re: Speed Issues
21-11-2013 6:45 PM
Re: Speed Issues
22-11-2013 9:09 AM
I've taken a look over your account and it seems you've had a few disconnections that caused SNR on your line to go up, which has then reduced your speed.
I've placed a SNR reset which by the time you see this should have rectified this and improved your speeds.
Re: Speed Issues
26-11-2013 7:14 PM
ADSL Up 448 / 3392 kbps
ADSL Status
Parameters
Upstream 448
Downstream 3392
SNR Margin(Upstream) 20.0
SNR Margin(Downstream) 8.2
Line Attenuation(Downstream) 46.0
Any suggestions? I am going to fit a filtered face plate to rule out internal wiring etc but other suggestions would be appreciated. Again many thanks for your help last time around.
Re: Speed Issues
26-11-2013 7:21 PM
Re: Speed Issues
27-11-2013 11:24 AM
Re: Speed Issues
27-11-2013 6:30 PM
Re: Speed Issues
27-11-2013 10:34 PM
ADSL Up 448 / 6272 kbps
Upstream 448
Downstream 6272
SNR Margin(Downstream) 5.9
Line Attenuation(Upstream) 22.0
Results Image not loaded
1. Best Effort Test: -provides background information.
Download Speed
2.4 Mbps
0 Mbps 7.15 Mbps
Max Achievable Speed
Download speedachieved during the test was - 2.4 Mbps
For your connection, the acceptable range of speeds is 0.6 Mbps-7.15 Mbps.
Additional Information:
Your DSL Connection Rate :6.27 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
IP Profile for your line is - 2.5 Mbps
If you wish to discuss these results please contact your Broadband Service Provider.
If you are experiencing problems with specific applications, servers or websites please contact your Broadband Service Provider for assistance.
Your test has completed please close this window to exit the performance tester.
Re: Speed Issues
28-11-2013 2:33 AM
PN can always do another SNR reset if it takes too long.
Re: Speed Issues
28-11-2013 10:08 AM
Re: Speed Issues
28-11-2013 10:23 PM
Download Speed
5.02 Mbps
0 Mbps 7.15 Mbps
Download speedachieved during the test was - 5.02 Mbps
IP Profile for your line is - 5.5 Mbps
Please visit the FAQ if you are unable to understand the test results.
one last question could you tell me if Interleaving is on or off on my connection?
Re: Speed Issues
29-11-2013 11:17 AM
It's currently on - it was off for a short while but turned itself back on on the 25th according to BTs systems.
Re: Speed Issues
29-11-2013 12:08 PM
Re: Speed Issues
29-11-2013 1:40 PM
