Speed Issue
tomxlisa
Speed Issue
Speeds seem to be getting quite annoying on plusnet now, have put up with it but thought its about time i speak out and ask about on here, normally get around 18Mb on http://www.speedtest.bbmax.co.uk/ when things are going good but at the moment its around 12Mb, most the time if i reboot the router it gets the speed back up again so something must be going on with the plusnet pipes or summat, anyone else noticed this, never had this issue at all when i was with Sky on LLU?.
Fixes: 62
Re: Speed Issue
I've had a look at your account and have run a few checks but I can't see anything obvious that might cause an occasional drop in speeds.
You'd be best making http://faults.plus.net your next port of call to report the issue.
Let me know if you hit any difficulties after doing that.
Adam.
 Adam Walker
tomxlisa
Re: Speed Issue
Speed seems to be back up now and i haven't moved pipes so maybe it was just a slight issue or something which resolved, i'll keep an eye on it before creating a fault.
Thanks.
Fixes: 62
Re: Speed Issue
No probs,
FYI you'd always better off raising a fault first if there's an issue like that before posting. (obviously I can't tell you when to post and when not to though!)
Glad to hear things have improved for you anyway.
 Adam Walker
