Speed Issue
- Speed Issue
- « Previous
- 1
- 2
- Next »
Re: Speed Issue
22-02-2008 5:04 PM
Well m8 hope you have more luck than me
almost in to week 3 and my speeds are getting worse
bt seem not to give a toss
have even got new modem to try to see if mine was faulty nope just as slow.
have to say that this is poor
http://www.mybroadbandspeed.co.uk/results/00283824.png
Message 16 of 22
(597 Views)
Re: Speed Issue
22-02-2008 5:26 PM
That does look pretty poor.
There is a lot to look at when it comes to speeds like that - Do you have an output of a BT speedtest you could post?
http://www.plus.net/support/broadband/troubleshooting/bt_speed_tester.shtml
Ian
Ian
Message 17 of 22
(597 Views)
Re: Speed Issue
22-02-2008 5:28 PM
@ monkeytrousers
I can see you replied to the ticket letting us know everything is back to normal, good to hear.
@fnuseless
Your ticket is with our logged faults team and they'll keep chasing BT for updates.
@fnuseless
Message 18 of 22
(597 Views)
Re: Speed Issue
22-02-2008 6:12 PM
that might have been the last time chris
but hey this is the next event which is now heading for a 3 week fault
just done bt test
Test1 comprises of Best Effort Test: -provides background information.
IP profile for your line is - 2000 kbps
DSL connection rate: 448 kbps(UP-STREAM) 2528 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 456 kbps
If you wish to discuss these results please contact your ISP.
If you are experiencing problems with specific applications, servers or websites please contact your ISP for assistance.
Your test has completed please close this window to exit the performance tester.
i have to say at least it now reads the connection as 2528 but not d/loading at that
check last ticket for even poorer result
i know this is not really plusnets fault but i am getting cheesed off paying for the gaming pro connectio and getting isdn {well almost}
just done bt test
Message 19 of 22
(597 Views)
Re: Speed Issue
23-02-2008 7:48 AM
noted in that last test my profile had changed to 2000k
for the last 3 weeks that has been like 700 or less
did test this morning and uess what
DSL connection rate: 448 kbps(UP-STREAM) 3232 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 1740 kbps
now the question has to be how long till it falls over again or has it been my modem!!!!!!!!/router
Message 20 of 22
(597 Views)
Re: Speed Issue
06-03-2008 12:36 PM
Have been having nearly identical issues with my broadband- working perfectly one day, greatly reduced speeds the next. The response to my ticket was very inconclusive- and frustrating. I'm getting this from the BT Speedtester:
IP profile for your line is - 7000 kbps
DSL connection rate: 448 kbps(UP-STREAM) 8096 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 53 kbps
VERY low actual IP, yes? This is from mybroadbandspeed.co.uk:
Plusnet has denied fault for low speed before, but persistent complaining and far too many phone calls resulted in an admittance of error and thus increase in speed. Hopefully it won't be as complicated this time around! Any advice is appreciated; am very tired of no adequate responses.
Message 21 of 22
(597 Views)
Re: Speed Issue
06-03-2008 7:26 PM
No; it was the very first thing I checked. Even when that does occur, speeds are better than they are now.
Message 22 of 22
(597 Views)
- « Previous
- 1
- 2
- Next »
