Speed Issue
- Speed Issue
Speed Issue
17-09-2012 8:25 PM
Hey,
I'm really baffled and could use some help with my broadband speed. Got a Thomson router and the stats are below. Was getting decent speeds over the weekend but today it's majorly dropped and i'm now struggling with 250kps. Any help would be much appreciated. I've plugged it into the test socket and getting the same results.
http://www.mybroadbandspeed.co.uk/results/172835701.png
DSL Connection
Link Information
Uptime: 3 days, 23:12:20
DSL Type: G.992.5 annex A
Maximum Bandwidth (Up/Down) [kbps/kbps]: 20,060 / 19,804
Bandwidth (Up/Down) [kbps/kbps]: 446 / 12,118
Data Transferred (Sent/Received) [MB/GB]: 881.65 / 3.26
Output Power (Up/Down) [dBm]: 12.5 / 16.5
Line Attenuation (Up/Down) [dB]: 8.0 / 14.0
SN Margin (Up/Down) [dB]: 21.0 / 14.0
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Framing (Local/Remote): 42 / 0
Loss of Signal (Local/Remote): 1,376,238 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 5,373,880 / 0
FEC Errors (Up/Down): 126 / 582,033
CRC Errors (Up/Down): 304 / 703
HEC Errors (Up/Down): 9 / 23,111
Cheers,
Graeme
DSL Connection
Link Information
Cheers,
Graeme
Message 1 of 7
(1,219 Views)
6 REPLIES 6
Re: Speed Issue
17-09-2012 8:35 PM
what are the results of this test http://speedtester.bt.com/ and what does https://portal.plus.net/my.html?action=data_transfer_speed say?
Message 2 of 7
(554 Views)
Re: Speed Issue
17-09-2012 9:12 PM
BT Speedtest
1. Best Effort Test: -provides background information.
Download Speed
0.17 Mbps
0 Mbps 21 Mbps
Max Achievable Speed
Download speedachieved during the test was - 0.17 Mbps
For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
IP Profile for your line is - 10.69 Mbps
Upload Speed
0.05 Mbps
0 Mbps 0.45 Mbps
Upload speed achieved during the test was - 0.05Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.45 Mbps
This test was not conclusive and further testing is required.This might be useful for your Broadband Service Provider to investigate the fault.
Plusnet Line Speed
Estimated line speed:
Not recorded (service activated before we introduced estimates).
Current line speed:
10.9 Mb
Download Speed
0.17 Mbps
0 Mbps 21 Mbps
Upload Speed
0.05 Mbps
0 Mbps 0.45 Mbps
Plusnet Line Speed
Current line speed:
10.9 Mb
Message 3 of 7
(554 Views)
Re: Speed Issue
17-09-2012 10:11 PM
Are you connected wirelessly or cabled directly to the router?
That's RPM to you!!
Message 4 of 7
(554 Views)
Re: Speed Issue
17-09-2012 10:26 PM
You haven't gone over your usage allowance have you? The stats seem to be ok, throughput aside.
Message 5 of 7
(554 Views)
Re: Speed Issue
18-09-2012 12:11 AM
My laptop is cabled directly to the router and nope i've definitely not went over my allowance. Its just a weird one! I've raised the issue now and await a response from Plusnet
Message 6 of 7
(554 Views)
Re: Speed Issue
18-09-2012 3:16 PM
Hi gpavlovic,
I've checked your connection and your profile has banded itself to a lower profile which gave you reduced speeds. Everything now appears to be back to as it was from what I can see.
You had a re-sync yesterday around 11.30am and it changed your profile.
Let me know how you are getting on.
Message 7 of 7
(554 Views)
