Speed Issue on Ulimited Fibre
akthus
After waiting over 3 weeks to be connected to fibre I got connected on Tuesday 12th Feb to fibre.
But the speed is about half of what I expected. I have been on the fibre now for a couple of days now and would expect at least 60 mb if not more.
I have opened a ticket #65939881 which shows 3 readings I have taken for the speed tests and they average at about 30 mb.
Please can somebody look at this.
13 REPLIES 13
akthus
Re: Speed Issue on Ulimited Fibre
The IP Profile for my line is showing 73.44 when I run the BT Tests.
Oldjim
Resting Legend
Fixes: 63
What about Current Line Speed here https://portal.plus.net/my.html?action=data_transfer_speed and are the tests wired or wireless
DrDave
Very important to run speed tests via a WIRED connection.
akthus
Hi OldJim / DrDave
It was a wired test.
This what I get when I go to https://portal.plus.net/m...ction=data_transfer_speed
Telephone number:
01422XXXXXXX
Phone exchange:
HALIFAX
Estimated line speed:
59Mb (Accurate to within +/- 1Mbit)  - Checked on 2013-02-14 19:47:07
Current line speed:
37 Mb
Oldjim
Resting Legend
Fixes: 63
That is your problem
Either raise a ticket asking for the Plusnet profile to be increased to the BT profile or phone in
akthus
Thanks OldJim will phone up.
DrDave
Yeah I'd say you've been assigned the 40/10 profile rather than the 80/20 as many did a few weeks back.
All dealt with seamlessly by PN staff here. Couldn't ask for any more tbh.
akthus
I have phoned in to PlusNet and am now waiting for the profile change.
Not sure why it could not be done straight away.
DrDave
It's not an instant process, I guess it has to be referred to BT or something.
Don't worry, it'll soon sort itself out, mine did. Patience!!!  Cheesy
akthus
Thanks for that DrDave.
I was told that it could take up to 10 days. Although I was under the impression that it was a profile change on PlusNets end. The BT profile is ok.
adamwalker
Fixes: 221
@akthus
The profiles on both ours and BT's systems are correct so I'm actually going to advise raising a fault to overcome this problem, I don't believe waiting will help: http://faults.plus.net
 Adam Walker
akthus
Adam thanks for checking it out for me.
It looks like the speed has gone up.
I got an email from one of your guys telling me that he had changed the profile because it was wrong on your end.
I will keep an eye on the speed for the next couple of days to make sure it stays above the 60 mb I am now getting.
orbrey
Hi akthus, glad that's sorted it - please let us know if it does drop again and we'll have another look. Hope it keeps up though.
